No Compression!
Old Sep 16, 2007 | 06:46 PM
danield's Avatar
danield
No Compression!
I have had a dead cylinder on my 1985 f250 6.9l truck and was not sure which one it was so I did a compression test today. All 7 cylinders were 400 lbs plus or minus 5 lbs. But all very close. The passengers rear cylinder has no compression. Yes it has "0" lbs of compression. I removed the test guage and put my finger over the hole and there was no pressure at all while cranking the engine. What Ideas do you have for this! My only guess is it dropped a valve and knocked a hole in the piston. I dont know what else could cause this cylinder to have 0 compression.
Old Sep 16, 2007 | 07:36 PM
Lead Head's Avatar
Lead Head
Granted this isn't a diesel, but some how on my ranger gasser, the exhaust side pushrod on Cyl1 fell off, causing it get 0 PSI compression. I would pull the valve cover and check things out
Old Sep 16, 2007 | 07:38 PM
matts156's Avatar
matts156
Probably a burned valve. I've pulled engines apart that had a D-shaped exhaust valve. It gets that bad because once there is an edge that can burn, it continues to burn until a significant portion of the valve is gone.
Old Sep 16, 2007 | 07:47 PM
danield's Avatar
danield
Great Ideas keep them coming, Lots of help!! I will be taking the valve cover off this week to investigate
Old Sep 16, 2007 | 08:36 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Oil sucked into the CDR and then on into the intake tends to be burned mostly in the rear cylinders.
Since motor oil has more BTU's than diesel does it makes the fire hotter in cylinder 7 and 8.
P.S. Your problem is in cylinder 7.
Old Sep 16, 2007 | 09:41 PM
catfish101's Avatar
catfish101
Pll the valve cover off and them the rocker assembly for that cylinder. Put shop air into the glowplug hole with a rubber tipped air gun. That will tell the story.
I knew an old man, when I was a kid, that lost a piston in a 300/6. He drove a block of wood in that hole and ran the engine on 5 cylinders for along time. You probably don't want to do that but I saw it done.
Old Sep 16, 2007 | 09:50 PM
PLC7.3's Avatar
PLC7.3
Catfish your telling your age........ you can't get that good wood anymore.......
Old Sep 16, 2007 | 10:11 PM
catfish101's Avatar
catfish101
I have some locust trees I need to clear out so I can put a plow in the ground in that spot that might just work. Widdle one down, soak it in pine tar and drive her home. What I don't use for fence posts I will gladly donate to the cause.
Old Sep 17, 2007 | 12:33 AM
DNewton's Avatar
DNewton
my truck may have the same problem, what should we do if this happened.....
Old Sep 17, 2007 | 09:16 PM
matts156's Avatar
matts156
If you do indeed have a burned valve, then you're looking at pulling the heads and getting a valve job. The air nozzle compression check is a great idea, and will definitely give you a good indication of where the failure is, but no matter which valve is dead, you're looking at pulling the head to get it fixed.
Old Sep 17, 2007 | 10:31 PM
tbone91's Avatar
tbone91
Just remember to keep away from the belts and fan when you apply air. Even though you don't get any compression on the gauge, there's still a remote possibility that the engine will kick...
Old Sep 18, 2007 | 12:06 AM
DNewton's Avatar
DNewton
just unhook the FSS before you try to keep it from kicking over....
TexasMarkIII
Jul 30, 2013 12:28 PM
RabidJade
Nov 1, 2011 11:26 PM
snipa
Sep 9, 2009 04:19 PM
Ranger1F150
31
Apr 9, 2007 01:31 PM
1955effie
May 21, 2006 05:17 AM
