what code reader do you all have?
later!! chris
A code reader can do just that & maybe erase codes, it's less costly .
A scantool is more expensive, but can do more, like read PID's from engine sensors, so thats a big help in diagnostic work.
Both of the above are portable, small & easy to use.
There are scan tools that'll work on OBD-1, OBD-2 & will, or are able to be reprogrammed for the new CAN network diagnostics, but these more versatile scan tools are more expensive & you'll need the specific hook up cables for the different brands of OBD-1 cars you have.
In 05, Santa bought me a Actron CP-9150 scantool kit, that covers all the families of Ford, GM & Chrysler vehicles, from 85, to present, with the hookup cables needed to connect to the OBD-1 vehicles, as well as the OBD-2 cable & it has lghter & battery hook up power connectors for under hood or in cabin driving work, as well as an extra long diagnostic cables, so if the diagnostic hook up connector is under hood, as it was on OBD-1 vehicles, you can run the cables into the cab, while someone drives the vehicle & you monitor the vehicles PID's while underway.
So long, say 8 ft., hook up cables are nice.
The laptop software driven tools are nice too, if you like lots of graphic displays, but they are larger heavier & less managable to work with underhood & some don't have cables long enough for you to get out of the drivers seat with it.
Also most laptop models won't cover pre OBD-2 models, so if you have older computer vehicles, be sure to inquire about the softwares coverage & if they offer the vehicle computer hook up cables, many, or most just dont cover OBD-1 vehicles.
Many of all the above don't cover the ABS, Chassis, or Transmission computers & can't retrieve codes from them.
Some code readers & scan tools can't read manufacturer specific engine computer codes either, they just read the generic P0 codes.
Some won't cover foreign OBD-1, or you must have a different model to scan them.
So imo you need a tool that'll at least read the maufacturer specific codes of the vehicles you have to work on.
You'll also want one able to read, or be reprogrammed to read the CAN diagnostics, on newer vehicles.
The Actron CP-9145 & CP-9150 scantools will.
So generally thats it, depends on what year & range you want to cover & in what depth you want to be able to do your diagnostics & how much money you want to spend.
My CP-9150 kit cost Santa about $250 in Nov 05, but I've seen it for less than $190 on E-Bay. So I imagine it would cost maybe $150 now, to get a decent scantool, that'll read PID's & manufacturer specific codes & cover OBD-2 & CAN vehicles, 95 & up, & maybe a little more. if you want to cover all OBD-1 US made vehicles back to about 85.
Just some thoughts for pondring.
