New Truck When to EDGE!
<TABLE><TBODY><TR><TD vAlign=top width="100%">what is a edge?
</TD><!-- KEN: 1-13-2007: show 300x250 ad-block to non-Club FTE users in the 1st post of every page --><!-- / Ken, end of hack --></TR></TBODY></TABLE>
Does the truck have the sensors to actually monitor any of these things, or do the advertisements just mean the tuner is capable? I understand some don't apply to every engine.
RPM
• MPH
• Engine Coolant Temp
• Engine Oil Temp
• Transmission Fluid Temp
• Cylinder Head Temp
• Air Intake Temp
• Line Pressure Control Desired
• Fuel Rail Pressure
• Output Shaft Speed
• Turbine Shaft Speed
• Manifold Air Flow
• Manifold Air Flow Sensor Voltage
• Variable Cam Timing Actual Advance
• Spark Advance
• Torque fuel/spark Limiting Status
• Fuel Economy
• Engine Load
• Accelerator Pedal Position
• Battery Voltage
RPM
• MPH
• Engine Oil Temp
• Air Intake Temp
• Manifold Air Flow
• Spark Advance
• Fuel Economy
• Engine Load
• Battery Voltage
