How to repair syncronizers?
Old Sep 16, 2007 | 09:35 AM
sdloe's Avatar
sdloe
I have a 78 F100 with a 4 speed (OD, no granny gear.) 2nd gear pops out when coasting down hill. Can I fix the syncronizer myself? I have not pulled any numbers off the tranny yet but thought some of you guys could help me regardless. Thanks.
Steven
Old Sep 16, 2007 | 03:41 PM
85e150's Avatar
85e150
You can get a rebuild kit for somewhere under $200.
I googled "ford srod rebuild kit" and this is the first hit:
http://www.drivetrain.com/transillsrod.html
Click on "parts list" and look around the site.
While you have it apart, bearings etc should be replace.
As for popping out of gear, that is not a synchro problem, that would be a worn shaft or linkage problem. Bad synchro results in grinding or very hard shifting.
Look around this site for folks converting to ZFs and Mazda 5 speeds if you find your box has a fatal problem.
carlsson
Mar 23, 2010 10:27 PM
timmosazz
Nov 16, 2008 02:17 PM
grumpy1
Apr 2, 2005 10:27 PM
mulletmaster55
1997 - 2003 F150
Feb 23, 2005 06:10 PM
87rustbucket
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 11, 2004 08:27 AM
