E40D problem
Old Sep 10, 2007 | 07:02 PM
ford firsttimer's Avatar
ford firsttimer
Cool E40D problem
This week-end my motorhome with a 460 and an E40D tranny gave me a big problem. From a dead stop we started up an 11 % grade and barely made it. The RPM stayed even, but we barely moved, about 2 mph. Got to the top and it was smoked. Got me home, but every rise or hill caused it to heat up again. Does this sound like converter problem ?
Old Sep 10, 2007 | 07:05 PM
73F100*8Mile's Avatar
73F100*8Mile
Sounds like a bad pump to me.
Old Sep 10, 2007 | 07:10 PM
ford firsttimer
Thanks 73 F100*8 mile
Is this a job a backyard mechanic could try ? Or is it off to the tranny shop ?
Old Sep 10, 2007 | 07:38 PM
73F100*8Mile
Well if it is indeed the problem, all you gotta do is pull the trans, pull the converter which just takes some muscle to slide off and then unlbolt and remove the pump and install the new one. I'm no trans pro but I'd let some other guys chime in that are E4OD pro's and see what they think. I'm more of a C6 guy which the E4OD was based on but things are a little different. The pump is a very do-able job though as long as you have a good, accurate torque wrench.
Old Sep 16, 2007 | 05:29 PM
Linemo's Avatar
Linemo
just my two cents worth but the E4OD is fairly complex tranny ie: computer controlled electronically shifted not only that if your trans heated up like you say I would be inclined to say you have caused damage beyond just the pump like bands planateries etc my suggestion would be to get a good tranny shop to look at it ! But the down side is they are expensive to repair also if you get it rebuilt ask about installing a better tourque converter and tranny cooler
nossliw
Sep 3, 2014 11:44 AM
kjjr20
Jan 16, 2014 02:24 PM
94shorty
Aug 21, 2009 11:23 AM
vanman13
13
May 1, 2007 05:56 AM
danny_1
Mar 6, 2000 12:48 PM
