How do I fix it?
Old Sep 15, 2007 | 09:29 PM
F0rdF0rever's Avatar
F0rdF0rever
How do I fix it?
I feel like an idiot for this one. I was working on my truck a couple of weeks ago and I accidentally put my knee on the hose that runs from the radiator to the tank. snapped the fitting right off the radiator. I put some jb weld on it and it held until tonight. So what the right fix for this one?
Old Sep 15, 2007 | 09:38 PM
c00nhunterjoe's Avatar
c00nhunterjoe
oh no! you broke it again! thats not good, i hate when that happens, sorry to say but that nipple isnt fixable, a new radiator is in order
how is she runnin since the o-rings? did you get the other side done?
Old Sep 15, 2007 | 09:45 PM
F0rdF0rever
I was afraid of that. Guess i'll have yo order one and put some more jb on it until it arrives. Other than that its been running good. I havent had a chance to do the other bank yet though. I was hoping to get it done tomorrow. What I did get done though is the front locknuts. I was totally amazed how much differnce the new and right parts made. Almost all the play and all the drifting on the highway is gone. I also shimmed my carrier bearing down but im still getting some vibration. I went with 1inch because I had some tubing in the shop. I'll have to try an go with half inch.
Old Sep 15, 2007 | 09:50 PM
F0rdF0rever
I just found out that I can get the radiator and hoses from advanced tomorrow. I think this is my truck telling me I need to change the coolant. Its been a LONG time. Any suggestions Joe on something I can get tomorrow for coolant?
Old Sep 15, 2007 | 09:57 PM
c00nhunterjoe
anything green and get the ford.... sheet, it used to be fw-16 but i think its vc-8 now i cant remember the new number
Old Sep 16, 2007 | 01:09 AM
powerstroked162's Avatar
powerstroked162
Yep yep, its vc-8 now Jed
Cowboy Steve
Old Sep 16, 2007 | 06:28 AM
c00nhunterjoe
man, good, the memory still works at late at night
Old Sep 16, 2007 | 08:36 AM
aldridgec's Avatar
aldridgec
I've seen some screw a pipe nipple into the broken off hole with some sealer. It's just luck as to how long it will hold I suppose.
Old Sep 16, 2007 | 08:45 AM
Cuda_jim's Avatar
Cuda_jim
I've done the same thing but not on our rads, it still holding after a couple years though.
BTW: aldridgec, got the carrier on Friday, I haven't un-packaged it yet, Thanks.
Old Sep 16, 2007 | 10:10 AM
1997F-350's Avatar
1997F-350
did you get a used one or buy new?
Old Sep 16, 2007 | 10:18 AM
F0rdF0rever
Oh man, almost 300 bucks for a new radiator. I think i'll give the pipe nipple a shot. I'll be sure to keep some jb in the glove box
Old Sep 16, 2007 | 10:42 AM
95psd's Avatar
95psd
If you could thread it with a tap, you could get some white loc tite 567, put that on the threads and once it sets up if there is enough thread surface I think that you would be ok.
Old Sep 16, 2007 | 10:49 AM
Cuda_jim's Avatar
Cuda_jim
It's used, he wanted an eaton posi. I'm going to replace the clutches anyway. This winter my truck is coming apart for a bunch of mods. Hopefully it will be in the 400+HP range.
Old Sep 16, 2007 | 10:51 AM
Cuda_jim's Avatar
Cuda_jim
You could try using a product called Marine Tech IIRC. It will fasten anything to anything......wel almost. I'll try to get a link for it. Kinda pricey but a lot less than a new rad.
Old Sep 16, 2007 | 11:02 AM
Action4478's Avatar
Action4478
A proper size barbed fitting , & a soldering iron on low , & weld it in....
Seal it wtih some JB or the like.....
I do it all the time ..I have even welded plastic intakes ....
Its already screwed up ,,
"You can't hurt a manure pile by throwing crap on it"
