Clearing codes???
Old Sep 15, 2007 | 05:02 PM
88PONY's Avatar
88PONY
Question Clearing codes???
Whats the proper way to clear trouble codes on a 1991 F-250? I've heard just disconnect the battery, and others say dont....
Thanks
Old Sep 15, 2007 | 05:14 PM
quicklook2's Avatar
quicklook2
disconnect the battery for 15 minutes or longer i you want too.
the truck needs to relearn stuff so drive it around a bit after.
Old Sep 15, 2007 | 05:30 PM
John Baldwin's Avatar
John Baldwin
Thumbs up
Pony,
If you want to do it quicker you can disconect the battery and then turn on the headlight switch for two minutes then shut it off. This will drain all the capacitors and reset the codes. Then reconnect the battery.
Of course waiting 15 minutes will do it also for sure.
Johnny
1988 Ford F-150 Custom 4.9L long bed 4-speed
1990 Ford Mustang LX 5.0 Hatchback AOD
1993 Ford Mustang LX Coupe 5-speed
..............................God Bless Henry Ford............................................
Old Sep 15, 2007 | 08:59 PM
88PONY's Avatar
88PONY
Question
ok, all i did was disconnect the negative cable.....should i remove both???
Old Sep 15, 2007 | 09:04 PM
radialarm's Avatar
radialarm
No. If you read a manual it always says to remove the neg. cable, because removing the pos. could damage some of your electronics when reconnecting it.
Old Sep 15, 2007 | 09:09 PM
quicklook2's Avatar
quicklook2
i am never in a hurry when reseting my computer.
that headlight thing made me laugh out loud.
where did you hear that from?
Old Sep 15, 2007 | 11:02 PM
Tennesseeduck's Avatar
Tennesseeduck
I never heard about turning on the headlights either. Just d/c the neg. for 15 min or use a scanner.
Old Sep 16, 2007 | 01:33 PM
88PONY's Avatar
88PONY
Cool
ok, i've done everything....new tps egr with sensor and iac, and the damn truck still has the check engine light on and idles at 2000rpms....i dont get it. i get codes 63 and 31....i give up
Old Sep 16, 2007 | 03:50 PM
Tennesseeduck
What are codes 63 and 31?
Old Sep 16, 2007 | 03:57 PM
Skandocious's Avatar
Skandocious
31 - PFE or EVP circuit below minimum voltage of 0.24 volts.
63 - TPS circuit below minimum 0.6 volts.
Did you replace the EGR valve or the EVP sensor? Sounds like EVP is your problem for the 31 code. As for the TPS code, not really sure if you have already tried replacing the TPS.
Old Sep 16, 2007 | 04:02 PM
quicklook2's Avatar
quicklook2
he just said he replaced the tps.
did you make all these changes at once?
did you clear the computer and go for a drive and let it reset itself?
Old Sep 16, 2007 | 06:35 PM
radialarm's Avatar
radialarm
Try these places to help find your problem:
www.fordfuelinjection.com/?p=35 EVP sensor
www.fordfuelinjection.com/?p=30 TPS
Old Sep 16, 2007 | 08:31 PM
netscaner's Avatar
netscaner
Maybe he has a problem with the 5 volt refference voltage those sensor voltages are derived from.
Old Sep 17, 2007 | 05:33 PM
88PONY's Avatar
88PONY
yes i replace all the sensors at once. i think i put the tps in wrong thats why its idleing high.
Old Sep 19, 2007 | 07:39 PM
EPNCSU2006's Avatar
EPNCSU2006
The headlight switch is meant to discharge any capacitors in the computer, but your guess is as good as mine as to whether or not it works. If you don't need the computer to re-learn everything, you can simply run the normal diagnostic check (pulling the codes) except when the codes are still flashing, pull the jumper wire that is grounding the STI. This erases the trouble codes but will not reset all of the computer's learned parameters.
jonrjen
6.7L Power Stroke Diesel
Nov 7, 2013 08:03 PM
weberr7
Jul 2, 2012 03:22 AM
modular2v
Feb 12, 2011 10:33 AM
r stene
1983 - 2012 Ranger & B-Series
Jan 27, 2011 11:10 AM
paradiddle
Electrical Systems/Wiring
Feb 9, 2004 11:30 AM
