Transfer Case Grenaded
Old Sep 14, 2007 | 11:07 PM
distortedcloud's Avatar
distortedcloud
Well, I was on my way to Race City in calgary to watch go to the drag strip(to watch), on the way down the highway, it started to vibrate violenty and not 20 seconds later my transfer case literally blew up, into several pieces, with the front driveshaft bouncing down the highway.
I got it off the highway, looked underneath and saw my chain from the case hanging and knew immediately what happened. The tow truck driver was extremely helpful on what to do next and where to get parts. Anyways, the money shots. Any donations are welcomed.
Old Sep 14, 2007 | 11:11 PM
mech2161's Avatar
mech2161
Check the u-joints closely. They have been known to bind and break things.
Old Sep 14, 2007 | 11:18 PM
distortedcloud
The left front was still engaged, which caused it to go. I guess the vacuum system on the hubs is an issue. Oh well, time to upgrade, warn hubs all the way.
Old Sep 14, 2007 | 11:31 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Wow that looks horrible. Its amazing what little harmonic vibrations can do. Lucky the front went and the rear stayed on, thats an expensive driveshaft. The part number for the Warn hubs is 38826, and it's about $180.
Old Sep 15, 2007 | 12:29 AM
HighOctane's Avatar
HighOctane
PMS: an obsession
has this happened to anyone else?
Old Sep 15, 2007 | 03:27 AM
77hiboyboy's Avatar
77hiboyboy
I had vibrations from vandalised bolts for the rear driveline (they loosened them) and it broke the back case on the transmission, right in front of the t-case. 230 bucks for new parts and I was back on my way. Minus my own labor.
Old Sep 15, 2007 | 06:33 AM
Kwikkordead's Avatar
Kwikkordead
Haha, that's a good one! I have never seen that before.
Old Sep 15, 2007 | 09:03 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Note to self - Remember to check that hubs are unlocked.
Man, sorry that happened to your truck. Glad it wasn't worse and thanks for sharing the experience.
Old Sep 15, 2007 | 12:10 PM
HighOctane's Avatar
HighOctane
PMS: an obsession
Is there away to check the non manual auto hubs? What is also the safe maximum speed to drive these trucks in 4x4? Thanks
Old Sep 15, 2007 | 03:36 PM
yamaguy's Avatar
yamaguy
I still don't quite understand what you think happened? I don't believe that can happen just because one of the hubs were locked. When was the last time you changed the fluid in the t-case?
Old Sep 15, 2007 | 03:41 PM
Badluck's Avatar
Badluck
yea i really dont think it happened becasue the hubs were in. I run mine in year round
Old Sep 15, 2007 | 03:44 PM
yamaguy's Avatar
yamaguy
He says that only one was in, but I still don't think that would do this.
Old Sep 15, 2007 | 03:47 PM
distortedcloud
Actually my dad(licensed mechanic) is around and took a look at it, figured it was either too much slack in the transfer case chain causing it to bounce over the sprocket, or the front driveshaft cv joint was fubar'ed causing it to be out of alignment with everything else.
And does anyone know if a 1996 f250(standard) transfer case will match up to a 2000 f250(auto)? I don't need 4x4, just something to get me moving again.
Old Sep 15, 2007 | 04:30 PM
mustang_gt_350's Avatar
mustang_gt_350
wow..A long time ago the chain broke in my dads jeep but it never blew out the case. i'm going to change out my transfer case fluid now. It will make me feel a little better 2 weeks from now when i hook to the sled. How much does the case hold?
Old Sep 15, 2007 | 07:01 PM
Kwikkordead
Two or three quarts of ATF.
