C6 issue.....
Old Sep 14, 2007 | 08:42 PM
1984F-150_351HO's Avatar
1984F-150_351HO
C6 issue.....
Alright, I'm at my ends with my 1988 F-250 351W C6...I've never had so many problems with a truck...In fact I find trucks that run and drive better in the junk yard! Enough of my rant though...
Alright this is the same truck that I had problems with before with the motor having all kinds of sensor and acceleration, power, and just everything problems. Now the transmission is acting up pretty bad, not as bad as before I changed the strawbery colored tranny fluid.
Currently I'm using what I call a redneck key to start my truck; it involves me turning the ingition to run then going under the truck and jumping the starter because something is so messed up with the tranny it wont start in park or neutral. It also decides to stall sometimes if I'm accelerating hard, come to a stop and then try to take off nicely...
IF anybody could tell me if this is a bad tranny problem that would be nice...its getting cooler out and come winter time I'm not going to want to crawl under my truck in the snow to start it...
Old Sep 14, 2007 | 08:49 PM
Skandocious's Avatar
Skandocious
EDIT: See next post.
Old Sep 14, 2007 | 08:57 PM
Skandocious
OOO, just found the part of the manual with instructions for ADJUSTING instead of replacing. Here ya go:
C6
1. Hold the steering column transmission selector lever against the Neutral stop.
2. Move the sliding block assembly on the neutral switch to the Neutral position and insert a 0.091 in. (2.3mm) gauge pin in the alignment hole on the terminal side of the switch.
3. Move the switch assembly housing so that the sliding block contacts the actuating pin lever. Secure the switch to the outer tube of the steering column and remove the gauge pin.
4. Check the operation of the switch. The engine should only start in Neutral and Park.
Here's a picture to go with her.
Old Sep 15, 2007 | 02:05 PM
1984F-150_351HO
Red face
Nifty, you even gave me a picture Sweet! I started reading and I was about to ask if you had one...but wow, Dood thats awesome.
I'll be ripping the thing apart on my day off Monday.
Thanks
Old Sep 15, 2007 | 03:16 PM
Skandocious
No problem buddy, let us know how it turns out.
Hotshot869
Jun 29, 2011 04:20 AM
FordNFishinLover
Mar 21, 2010 02:06 PM
capn kirk
Jan 21, 2008 12:30 PM
BrandyB
1978 - 1996 Big Bronco
Jan 2, 2008 08:23 AM
richard k
15
Jan 30, 2001 08:13 PM
