trailer wiring
Sep 14, 2007 | 10:39 AM
trailer wiring
went to hook up a 10K lbs trailer to haul a skidsteer and the ground is not found on the factory wiring on the truck hitch. Am I missing something?
Sep 17, 2007 | 02:34 PM
Bumped you up to SuperDuty to see if anyone knows.
Sep 17, 2007 | 03:04 PM
Ground is the WHITE wire. If you dont have one just run a wire to a good bolt on the truck side and the same with the trailer side...
Sep 17, 2007 | 03:22 PM
50K truck and I have to run wires???
Sep 17, 2007 | 03:53 PM
No, you should not have to run wires.
But maybe yours is damaged and Jeff gave you a place to start.
My connector assy under my rear bumber got damaged from driving/backing over things ... and certain wires would not work.
Sep 17, 2007 | 04:16 PM
Quote:
What kind of SD do you have? (year, model, config, etc.)
If it is still under warranty...then just go get it taken care of at the dealer.
biz
Sep 17, 2007 | 04:40 PM
Look on the wiring plug cover, it should show a pin diagram and one of the botton pins should be ground. Then check that pin with a test light or ohmmeter to see if its working.
Sep 17, 2007 | 06:03 PM
kioolt
Electrical Systems/Wiring
25
Jul 20, 2011 10:36 PM
BENG0924
16
Oct 17, 2008 04:20 PM
tnscrew
1997 - 2003 F150
Jan 4, 2003 09:34 PM
fast_eddy
1978 - 1996 Big Bronco
May 10, 2002 08:14 AM
deere81
Aug 31, 2001 07:17 PM
