Kam code
Old Sep 13, 2007 | 08:46 PM
suzuki_vinson's Avatar
suzuki_vinson
Question Kam code
My truck runs rough when you accelerate slowly. I have a code puller and it says it pulls a kam code. What is this????
Old Sep 13, 2007 | 09:02 PM
Izzy351's Avatar
Izzy351
KAM = "Keep Alive Memory". It's supposed to remember everything specific to your particular truck. Sounds like it's dumping for some reason. I've read about that before, but can't recall what the cause was. I'm sure someone will chime in with the goods...
Joe
nlemerise's Avatar
nlemerise
As far as I know KAM stands for Keep Alive Memory...it is where the OBDII system stores info about the problems it finds in the trucks systems. I have no idea why you would find that as an error though. We usually get DTC codes reported, this is the first time I have ever heard of a KAM error.
Old Sep 13, 2007 | 09:21 PM
medhvac's Avatar
medhvac
Do you have a programmer on your truck? that code comes up when you change tunes
Old Sep 13, 2007 | 10:45 PM
suzuki_vinson
Yes i just put a juice with attitude on it yesterday. It seems to be doing better. I cleared the code and let it sit for a while. Im a little nervous tho about the programmer. It seems to give it alot more power. But sounds like its knocking or something when it idles.
Old Sep 13, 2007 | 10:50 PM
medhvac's Avatar
medhvac
no need to check the code all the time !just have fun with your mods! good luck!
Old Sep 13, 2007 | 10:54 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Well your fun with Edge has just begun. Hope you get better support than some I have heard here. To answer your question though, the KAM error is likely tied to the tuner and not a cause of the knock, (the KAM error), the knock is likely from increased oil pressure to the injectors from the tune.
Old Sep 13, 2007 | 10:59 PM
medhvac's Avatar
medhvac
so what are u trying to say?
Old Sep 13, 2007 | 11:08 PM
Tenn01PSD350
Uhmm, well, I better shut up because the links escape me at the moment, but I have seen posts about customer support when Edge stuff goes on the fritz and it wasn't pretty. Since I have not archived any of that I will shut up except to say I have seen them.
We agree where the KAM error may come from and that is probably about it. I am sure the Edge tunes are far better than stock. So is a 10K mod too though.
EDIT: BTW, my #8 LL injector is louder with my DP as it was with the TS. He has a LL too.
Old Sep 14, 2007 | 03:09 AM
ron's power stroke's Avatar
ron's power stroke
have you unhooked the batteries ??? I have pulled that code a couple of times..Amiller told me it was do to the batteries being un hooked for too long then re hooked..both times I unhooked them that code would should show up..it may show a couple more times but then it will go away...
Old Sep 14, 2007 | 08:53 AM
SLAYER1's Avatar
SLAYER1
when i had the edge on my truck when i got on it hard i would see the check engine light flash momentarily, one of the codes i always got was the kam
Old Sep 14, 2007 | 09:38 PM
medhvac's Avatar
medhvac
i think u may have someting else going on there with your truck!i never get that check engine light when i get on it with my edge tuner!but i cant point u in the right direction!
Old Sep 17, 2007 | 08:34 AM
SLAYER1's Avatar
SLAYER1
I got rid of the edge and got a superchips and never got the check engine light again
Old Sep 17, 2007 | 06:11 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
It will depend on which Kam Error code you have
P0603/P0605 is normal to read off after installing a chip or programmer or you disconnected the batteries or there was some kind of power loss to the PCM.
P0606 is questionable. It does mean internal PCM failure, but doesn't mean it is completely toasted. Recoverable, maybe. ???
Which code are you getting?
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
kawa
Jan 12, 2008 02:13 PM
oddjobs2do
Aug 23, 2007 02:57 PM
jsrdaily
May 31, 2007 09:00 AM
funzjb1
Apr 3, 2006 06:25 AM
LEGENDS15
Sep 20, 2004 09:07 PM
