KAM sensor
Old Apr 2, 2006 | 10:44 PM
funzjb1's Avatar
funzjb1
Unhappy KAM sensor
My question is: is the KAM ( keep alive memory) sensor just that? My 96' f-250 PSD has a strange problem of dying when I let off the trottle coming to and idle it just dies completly. I put a new CAM sensor about a month ago. The trouble code says KAM sensor error but it does not do it all the time about 75% of it. Is this something easy to change?
Old Apr 3, 2006 | 05:12 AM
tjbeggs's Avatar
tjbeggs
don't think there is a KAM sensor. what is the code number you get? i would suspect a tps or idle validation switch issue with your problem but let see what that code number is first.
Old Apr 3, 2006 | 06:25 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Keep Alive Memory is internal to the engine computer (ECM). The only reason a KAM code would set is if you lost B+ feed/ground to the ECM or there is an ECM fault.
Cody
Sledhead3
20
Sep 20, 2016 01:09 PM
dannyboy950
Jul 6, 2015 09:14 AM
lonewolf78
1978 - 1996 Big Bronco
Jan 12, 2015 09:45 PM
John7894
Apr 1, 2007 03:40 PM
bhs2869
Feb 4, 2004 01:00 PM
