351w problems
Old Sep 11, 2007 | 03:15 PM
BigFordThunder's Avatar
BigFordThunder
351w problems
I have an 88 f-150 with a 351 and its having a problem like its not getting fuel sometimes. whenever im starting from a stop and if i press the gas to accelerate, at around 30/kmh itll stop accelerating and kind of pause for a second or 2 and if i keep my foot on the gas then itll pick up again then its fine usually until i slow down again to a stop or almost stop. the fuel pump in the tank and the high pressure pump in the frame was just changed a year and a half ago. i can also drive the truck fine for a good 10 min when its cold until it starts happening. any idea what this could be would be greatly appreciated.
thanks
Old Sep 11, 2007 | 03:25 PM
HemiEater's Avatar
HemiEater
Pull the codes.......Go from there,
Auto Zone will do it for free.
Old Sep 11, 2007 | 03:28 PM
BigFordThunder
OBD I Codes? sorry.. im not good with engines..
Old Sep 11, 2007 | 03:31 PM
HemiEater's Avatar
HemiEater
Take it to AZ and let them hook it up to thier scanner......
Old Sep 11, 2007 | 04:18 PM
flareside_thunder's Avatar
flareside_thunder
Yes, OBD 1....AZ and ADA don't all have the OBD1 scanners...Ilucked out.....abuddy of mine has the OBD1......
Old Sep 11, 2007 | 04:21 PM
BigFordThunder
ok. my buddy owns a shop and i work there for him on the weekends for some extra cash and hes got an OBD I so ill check it out on sat and see what happens.. hopfully good news!!
Old Sep 11, 2007 | 05:22 PM
Kemicalburns's Avatar
Kemicalburns
also check your fuel pressure at the rail with key on engine off. it should be 39psi
ChevySucks11
Bronco II
Jul 5, 2011 12:30 PM
Hotshot869
Jun 29, 2011 04:20 AM
FEman72
Jul 24, 2010 08:44 PM
pipman76
Jun 11, 2008 03:17 PM
van-man
Feb 2, 2006 06:49 AM
