Help with codes
Old Sep 11, 2007 | 06:43 PM
bigred66's Avatar
bigred66
Help with codes
Just got my new engine in and have about 50 miles on it. Somethings definately not right. Its a 5.0 out of a 95 bronco set to 12 deg timing. The engine starts but when i start to drive down the road it feels like a moped cause i dont have any power. I step on the gas pedal and it barely picks up speed, takes a good while just to get up to 30mph. I'm getting codes 412, and 538. I checked the timing before and after I pulled the spout connector and got the same reading each time. Thanks for any help
Old Sep 11, 2007 | 10:22 PM
LxMan1's Avatar
LxMan1
Well that's not right. It should show way advanced with the spout connector plugged in. For some reason you are not getting any advance. Double check and make sure all of the sensors are plugged in.
