Why does the center bracket bolt to the cast pumpkin?
Do to the fact that the center bracket mounts to the pumpkin, the center bracket must be loosend and moved to remove the diff cover also what if you have an A/M diff cover installed will the center bracket still mount correctly?
There is now additional stress put on the cast pumpkin cove flange, what are the potential problems of this mounting point?
Why not just use to U-bolts to mount the center bracket to the axle tube and not mount it to the pumpkin flange?
Moving this thread back up. Hopefully J.M.F.R will respond to these questions.
Wow... the guy comes along, gets us all excited and can't be bothered to come back and close some deals? I'd love to get an answer to the shipping to canada question along with maybe a PDF of the installation instructions....
I just sent him a PM to see if he can check out the thread and answer the questions. He probably just hasn't seen it in awhile. If you don't come on here everyday it is difficult to keep up with everything.
Just and FYI, i have found from talking to a well respected tech who has dealt with this issue, that you cannot install the dual stabilizer setup on factory stock suspension trucks. It does not matter if the system is from Fabtech, Rough Country or Donahoe Racing. You need a minimum of a 4-inch suspension lift to be able to install the dual shock setup. The problem with installing them on a stock suspension truck is that on rough road conditions the track bar comes in contact with the dual steering stailizer setup.
