I would buy from somewhere else. If you can't get information when you are wanting to spend your money with them, imagine how hard it will be to get their support after they have gotten your money.
I have an 2005 SD with 17" wheels would it fit it, my truck is at stock height.
~Gage~
No it will hit the track bar on rough roads. Only option on a stock height truck is to replace the factory steering stabilizer with a HD unit in the same location using factory mounts.
There currently is no dual shock steering stabilizer replacement for the 05-07 SD trucks. Your only option is to replace the factory unit with a HD replacement unit that mounts in the factory location using the factory mounts. Brand of your choice.
Donohoe Racing makes a good dual-stabilizer unit. Fox Racing Shocks, AKA FoxShox, is coming out with a stabilizer in a couple of months. I've spoken to a couple of different people at Bilstein and they have no plans whatsoever of making a stabilizer for the 05-07 Super Duty.
Sorry this got lost in the shuffle, for the non-lifted leaf spring front SD then your choices for a horizontal dual steering stabilizer is Donahoe Racing (spendy $500-600) or Fabtech $160. These will also work on lifted leaf spring and coil spring SD.
None of the horizontal dual steering stabilizers will work on a non-lifted coil spring front end SD.
This jack *** sponser needs to be taken off FTE. He will not answer anybodys questions when it comes down to Tech issues. Im not not happy at all with this A** H$$ and his company. Abandon everybodys questions and no response.
