Sponsored by: Real Truck
05-07 Problem Solver
Old Sep 12, 2007 | 09:49 AM
snelldawg's Avatar
snelldawg
If someone can explain the difference of the way the Fabtech dual in line stabilizer mounts versus the new Rough Country one that would be cool.
I understand that there is a difference in the shocks but I'm trying to see if the way one mounts is better than the other before I pull the trigger.
Thanks
Old Sep 12, 2007 | 01:27 PM
blackhat620's Avatar
blackhat620
J.M.F.R,
Why does the center bracket bolt to the cast pumpkin?
Do to the fact that the center bracket mounts to the pumpkin, the center bracket must be loosend and moved to remove the diff cover also what if you have an A/M diff cover installed will the center bracket still mount correctly?
There is now additional stress put on the cast pumpkin cove flange, what are the potential problems of this mounting point?
Why not just use to U-bolts to mount the center bracket to the axle tube and not mount it to the pumpkin flange?
Old Sep 12, 2007 | 02:07 PM
snelldawg's Avatar
snelldawg
blackhat620,
I noticed the same thing. That's why i questioned it versus the Fabtech dual that mounts differently
Old Sep 14, 2007 | 06:43 PM
blackhat620
Originally Posted by blackhat620
J.M.F.R,
Moving this thread back up. Hopefully J.M.F.R will respond to these questions.
Old Sep 17, 2007 | 04:48 PM
tlfbx23's Avatar
tlfbx23
I am also interested in having the above questions addressed. A lot of response early on but now what?
Old Sep 18, 2007 | 11:33 AM
Capital Customs's Avatar
Capital Customs
My 2005 F 250. king ranch has 24" wheels will it work with them.
Old Sep 19, 2007 | 04:22 PM
snelldawg's Avatar
snelldawg
Bumped again to get a response out of JMFR hopefully
Old Sep 19, 2007 | 06:26 PM
Beach_Bob's Avatar
Beach_Bob
Wow... the guy comes along, gets us all excited and can't be bothered to come back and close some deals? I'd love to get an answer to the shipping to canada question along with maybe a PDF of the installation instructions....
Old Sep 19, 2007 | 06:33 PM
Capital Customs
I would realy like to know also my truck shakes bad with the large wheels. tried everything else need info before spending any more.
Old Sep 19, 2007 | 09:19 PM
F250tuff's Avatar
F250tuff
He was on here today:
Last Activity: Today 12:18 PM
Why can't he answer some simple questions? I'm interested as well.
Old Sep 19, 2007 | 09:22 PM
WildWildWest's Avatar
WildWildWest
I just sent him a PM to see if he can check out the thread and answer the questions. He probably just hasn't seen it in awhile. If you don't come on here everyday it is difficult to keep up with everything.
Old Sep 26, 2007 | 03:23 PM
snelldawg's Avatar
snelldawg
bump for update
Old Sep 26, 2007 | 06:13 PM
  #28
mrxlh's Avatar
mrxlh
bumped again,
Interested as well, as my oem one started leaking about 6 months ago, can tell a big difference now that all the oil is out.
Old Sep 26, 2007 | 07:34 PM
  #29
blackhat620
Just and FYI, i have found from talking to a well respected tech who has dealt with this issue, that you cannot install the dual stabilizer setup on factory stock suspension trucks. It does not matter if the system is from Fabtech, Rough Country or Donahoe Racing. You need a minimum of a 4-inch suspension lift to be able to install the dual shock setup. The problem with installing them on a stock suspension truck is that on rough road conditions the track bar comes in contact with the dual steering stailizer setup.
Old Sep 26, 2007 | 10:43 PM
  #30
shoobear's Avatar
shoobear
pm sent.....
