Code readers
Old Sep 10, 2007 | 09:57 AM
dcara's Avatar
dcara
Code readers
My truck was cutting out pretty bad this morning coming into work and the SES light came on so I was thinking about getting a code reader.
Its strange that it only seems to cutout when its raining.
I noticed that some say they will read codes for cars and light trucks, others say that they will also clear the codes, and still other say that they will stream data on fuel pressure and other stuff. Any comments?
Ebay has them from $8 to $100
Old Sep 10, 2007 | 09:59 AM
rbaker6336's Avatar
rbaker6336
They probably won't read the Powerstroke
Old Sep 10, 2007 | 10:17 AM
HighOctane's Avatar
HighOctane
PMS: an obsession
Check this out
http://www.itpdiesel.com/store.php?c...on=show_detail
Old Sep 10, 2007 | 10:21 AM
Action4478's Avatar
Action4478
Try cleaning the CPS connector & seal it with some dialectric grease....Oddly enough ,,,also have the alternator checked...
Old Sep 10, 2007 | 01:29 PM
dcara's Avatar
dcara
"They probably won't read the Powerstroke"
rbaker - I don't understand. Doesn't the Powerstroke use one of the standard OBD protocols? If not what protocol does it use. I know my mechanic's code reader reads standard protocols and he has read mine before, including some of the transmission codes.
"Check this out
http://www.itpdiesel.com/store.php?...ion=show_detail"
Definately pretty cool..and pricey ($341 plus a laptop). But thats not a bad idea. I cant help but think though that I could buy a real lowend laptop for $341, write my own software read loop, parse the OBD data, import to spreadsheet and graph it.
Old Sep 10, 2007 | 01:52 PM
rbaker6336's Avatar
rbaker6336
the powerstroke is non-odb2 you can get free software at www.obd-2.com I guess the connections could be homemade to hook to computer
only need cheapy puter
Old Sep 10, 2007 | 01:59 PM
bdrummonds's Avatar
bdrummonds
Doug,
Its not so much that the PSD is not in OBDII code it is its just in a different language from the standard OBDII. If I start sprakin ze duetch and habla espanol as well as hundern ze durden, yes, you can read it, but might not understand it, and may misinterpret it. Look On ebay for a used superchips/bully dog/edge DOWNLOADER they will all read 7.3 diesel code and can be had pretty for cheap.
steveamann
13
May 5, 2013 03:33 PM
chuckletson
Jan 26, 2013 04:47 PM
92will
Jul 28, 2011 08:28 PM
goonski
1997 - 2003 F150
Nov 24, 2008 04:23 PM
Lance_I
Oct 15, 2006 08:10 PM
