Bronco II Ford Bronco II
Fuel gauge not working
Old Sep 9, 2007 | 08:11 PM
OlpA77's Avatar
OlpA77
I have a 1987 Bronco II 4x4 with a 2.9L. This ride is new to me. The fuel gauge dies not work at all. The gauge does not move ever just stays on E. Is there a way to test the gauge to see if it works okay? I dont want to replace the sending unit if it is working fine and the gauge is bad.
Thanks,
Aaron
Old Sep 9, 2007 | 10:16 PM
fl1a's Avatar
fl1a
The gauge itself should have a resistance of 10 to 14 ohms. The wire to the sender
located on the drivers side fender apron is a yellow/white stripe wire coming out of
the firewall to a connector originally positioned nearest the firewall. after that
connector ( C118 ) the wire goes to the tank. The sender should have a maximum
resistance of 75 ohms, and a minimum of 10 ohms between the sender wire and
ground. Do not test for resistance with ignition or accessory power on.
Old Sep 17, 2007 | 05:46 AM
DodgeBoy97's Avatar
DodgeBoy97
your float could be sunk that's what it was on mine it was dead on e never moving i thought electrical or something after a lot of b/s testing we dropped the tank and there it was the float had holes all over it I'd say check that cause its easy to fix and cost 6 bucks at napa, if that's it
aaron4vt
Feb 28, 2016 07:18 AM
samickguy15
Apr 9, 2015 01:32 AM
beckman
Jul 10, 2014 11:39 PM
tshrager
49
May 8, 2013 01:03 AM
asmith6
Sep 22, 2008 11:10 AM
