what's your opinion on high egt's?
![Question](images/icons/icon5.gif)
I have always heard that 1250 is high but I recently put gauges on a friends truck and we took it out for a drive to see how hot he was letting it get.
He mashed the pedal until it got up to 1400 and he wasn't worried at all. He has never had problems with anything and has always driven the truck that way.
The chip he had was a superchip on the first level and the 10k mod. The 10k mod is when it really got hot fast.
What do you think is hot? How hot do you let yours go?
I feel fine with 1250. I have pulled hills with 8k in tow for roughly 5 min at 1200*. This is the hottest I would run for extended periods. Besides, unless you have huge injectors (b codes etc) and insufficient turbo the only time MOST people will have to worry about extended periods of high heat is when under load like with towing. I have seen some idiots drive every second of there commute like they stole it, that's why I say MOST.
I've run mine for extended periods on long grades at 1200°-1250° (pre turbo) and so far all is well. I've hit 1400°+ plenty for short romps, but never for more than a brief moment. I always let her cool down before shut down, and I'm always on top of oil changes. There are a lot of factors to consider in addition to the EGT's.
Austin
Austin
What if a group of 8 mountain climbers who weighed 150 lb each went climbing up a 1000 ft mountain using a rope that was rated to hold 1200 lbs without breaking. Would you want to be in that group? I'd rather be in a group of 7 (if I was stupid enough to do this in the first place) that was only placing a 1050 lb load on the rope rated for 1200 lbs! I don't even care if the rope is rated for 1250 or 1300 lbs, I still wouldn't allow more than 7 climbers to use it. And this conclusion doesn't even consider the accuracy of the scale was that was used to weigh the climbers in the first place! I've been involved with engineering specifications for over 40 years, and I know how iffy and down right flakey some of them are.
Of course it's no concern of mine how high anyone wants to run their EGT's, but I do advise some caution when giving advice to others. Case in point is lacustoms, who I advised to exercise caution when towing with his chip, and gave him a link to my EGT thread. Then he goes an cooks his engine, and inquires about how badly damaged it might be, and I gave some boiling point at altitude info and again cautioned about EGT, and his response was that everyone else here had told him that it's just fine to tow at 1200F all day long, so he had to learn the hard way that it's not. Then poor lacustoms himself boils over, probably in part due to his following bad EGT advice given on this forum!
As I stated in my post and as others mentioned, there are a lot more factors in what is safe for EGTs.
There are so many variables and differences such as miles, kind of miles
oil pump condition, maintenance history.....the list is endless.
It is important to understand that everybody is going to have different opinions and experiences and that the final decision is, as always the owner of the truck.
Austin
Austin
