OK, did a search, do you know how many "actuator" posts there are?
Anyway, here's the deal. The quarter window actuator still works, but the joint (?) in it seems to be getting weak. Left side has no play at all, right side, I can move the window up probably 1/2 inch. I don't trust it going down the road any more, don't want to lose the whole window after reading some threads about the cost of replacement.
I took a quick look, I didn't see that this is a serviceable part, that it can be tightened up. Am I missing something? I read that you can replace it, but that the kit includes the motor, is this true? Don't need the motor, but if that's the only way to go.... Is this a stealer only part, or is there an aftermarket?
I googled "2000 excursion quarter window actuator" and got a lot of salvage yard hits, but first glance didn't see a "new" part. Will check again when I have faster access at work.
What is the correct term for this part/assembly?
I have the 2004 wiring diagram book X 250-550 and it only names the motor "power vent window motor" (right and left) same motor 151-44
It's the wiring book so it doesn't show the levers or hinges.....
