Transmission Problems E4OD
Old Jun 29, 2014 | 09:57 PM
  #31
West f150 302 5.0's Avatar
West f150 302 5.0
I have similar problems I was told vss and pcm could be bad
Old Jun 29, 2014 | 10:09 PM
  #32
FORDF250HDXLT's Avatar
FORDF250HDXLT
you were not told wrong.those are possibilities.in the vast amount of possibilities,those are some of the more rare ones and not a decent starting point,but true enough phrase in it's own right i suppose.
the codes and a new thread are the best places to begin.
Old Jun 8, 2021 | 01:24 PM
  #33
Zapper79's Avatar
Zapper79
E40d transmission.
I swapped tge 300 6 out of my 95 f 150 to a 5.0 from a 89 f150. I was gonna swap the tranny also but the harness wouldn't work so i left the e40d in it. I was having issues with hard shifts before and they seem to have gotten worse. I changed harness for the transmission still having the same issue. I replaced the cluster and now the lights are flashing Speedo bouncing shifting crazy think it is the shift solenoid but im not sure anymore. Any help would be greatly appreciated.
Old Jun 8, 2021 | 01:25 PM
  #34
Zapper79's Avatar
Zapper79
E40d transmission.
Old Jun 8, 2021 | 09:28 PM
  #35
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What PCM are you using? I assume you changed it to one for the 5.0L because one from a 300 won't operate a V8. Did the PCM you installed come from a truck with an E4OD? If not, that's your problem. You MUST have a PCM that operates a 5.0L/E4OD. No other PCM can be made to work.
Old Jul 11, 2021 | 07:48 PM
  #36
dwriedt's Avatar
dwriedt
Exclamation E4OD transmission problem
just got it rebuilt and it throws it self in to neutral and wont go in to 4th and od help please and there is no codes
Old Jul 11, 2021 | 08:06 PM
  #37
Mark Kovalsky
Fourth gear is overdrive. They are two names for the same gear.
It would help a lot if you would answer these questions.
Old Jul 15, 2021 | 07:59 PM
  #38
dwriedt's Avatar
dwriedt
i had someone doing work to it idk if the right one got put in and its 5.8
Old Jul 16, 2021 | 11:21 AM
  #39
torq'ta 5 8's Avatar
torq'ta 5 8
Y'all Confused Mark, Mark that was 2 different people posting, zapper didnt answer you, then dwriedt chimed in with their question, so it falls under zapper needs to answer Marks question, and dwriedt should take his back under warranty, and tell them it isnt fixed, because thats a lot of money spent to still have issues.
Encho
19
Feb 20, 2016 02:26 PM
stevenjf88
Oct 28, 2015 10:39 PM
anelson2964
Jun 19, 2014 02:17 PM
sknaggs185
Mar 19, 2009 10:59 PM
sknaggs185
New Member Introductions
Mar 17, 2009 10:06 PM
