6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
truck's acting weird..
Old Sep 6, 2007 | 01:38 AM
fordstroker's Avatar
fordstroker
hey guys, well i was driving today and when i take off from a stop or roll and get on the throttle pretty hard, the truck falls on its face and shakes and sputters..almost like a miss..i know it wasn't just the regen because it just went through one earlier in the day and plus i know what it feels like driving during regen and this was different..it only does it when on the throttle fairly hard...dont know if it could be an injector problem or what? any of you have any ideas on this??
Old Sep 6, 2007 | 01:49 AM
greythorn3's Avatar
greythorn3
take it to the stealership im sure they will be more then happy to help you.
Ray
Old Sep 6, 2007 | 01:58 AM
fordstroker
well i know that...can't get there for a couple days...i'm trying to see if anyone else has maybe had the same problem...
Old Sep 6, 2007 | 05:39 AM
firehawk198's Avatar
firehawk198
My buddy had it happen to his. It was an electrical connection to the injector. They replaced the connector and it it has been perfect since then. Just an possibility.
Old Sep 6, 2007 | 08:48 AM
pugster's Avatar
pugster
Smile Check Injector
Sounds like mine at 600 miles. An injector was loose, eventually shutting down the engine. Get it checked, but not at Joe Myers.
Old Sep 7, 2007 | 12:24 PM
fordstroker
i had an appointment to take it in to the dealer today, and low and behold it stops acting up..weird...thats always the case, can't get it to act up when you need it to..probly should have went ahead and took it in to get the pcm updated...guess we'll see if it does it again anytime soon...weird..
Old Sep 9, 2007 | 12:29 PM
SANDDEMON08's Avatar
SANDDEMON08
Whats the build date on the truck?
Old Sep 9, 2007 | 03:08 PM
reddawg7's Avatar
reddawg7
shutter at take off
My truck does the same thing but only when I am pulling my 5th wheel. From a stop it will shutter and vibrate . took it to the stealership and they could not find what the problem was. A couple of weeks later I was by the stealership with my trailer so I stopped in and had the service mgr get the best diesel mechanic and we took off in my truck. the mechanic says its the drive line shutter when loaded. he futher said if I put air bags on the rear it would not do it. I thought it was the tranny and that concerned me but they assured me it was drive line shutter.
Old Sep 9, 2007 | 04:41 PM
mrxlh's Avatar
mrxlh
If it were me I would have them put that it writing on the service ticket, and carry that back to Ford. Make them pay for the airbags, if that is whats going to correct their problem. Hate to be nitpicky, but Ford has gone out of their way to make it a pain to get anything done under warranty, chipped or not. I would by all means hold them accountable to hold up their end of the bargain.
Old Sep 9, 2007 | 11:11 PM
fordstroker
the build date on my truck is 6-07. earlier in this thread i said that the truck stopped doing what it was doing, but today i was driving and it started again..when get get on the throttle hard it starts sputtering and i noticed today that when it was doing that it was blowing white smoke out of the tailpipe...don't know what could be going on, im for sure going to take it in tomorrow whether its messing up or not..my luck it'll run fine and they won't be able to find anything wrong with it...
Old Sep 10, 2007 | 11:45 AM
se7en30's Avatar
se7en30
driveline shutter usually only happens when you install a leveling kit; reddawg7 do you have a leveling kit on yours?
Old Sep 10, 2007 | 02:00 PM
BowTieHatr's Avatar
BowTieHatr
there are some trucks that have a driveline shudder on hard accell, more noticeable when loaded or lifted. there is a tsb out to install some shims on the center support to help out with the shudder.
Old Sep 10, 2007 | 03:36 PM
kimminau2's Avatar
kimminau2
Mine did that when it was loaded, but then the differential crapped out and they replaced it. Have not had the problem since.
Old Sep 10, 2007 | 04:42 PM
fordstroker
i know mine isn't driveline shutter..mine loses power and blows white smoke out of the tailpipe..the truck will run fine for a little while and then it will start acting up..doesnt do it all the time..
Old Sep 11, 2007 | 06:51 AM
BowTieHatr's Avatar
BowTieHatr
try to find a more competent dealer.
