bulb covers
Old Sep 16, 2007 | 11:03 PM
OregonF350's Avatar
OregonF350
Originally Posted by LvTitan
as far as the T10, i didnt see one on this link that is the one i would need, the bulb i have is some sort of twist lock that goes into the back of the gauge, but the wires dont go to the bulb,
which bulb would i need to order to fit my gauge, ???
I assume we are still talking about the Isspro Boost guage. The twist lock is just the bulb housing, the bulb just pulls straight out off the housing. So the first two on the T10 link should fit.
I haven't ordered anything yet but when I do I'll be sure to post the results.
Old Sep 16, 2007 | 11:20 PM
LvTitan's Avatar
LvTitan
a ha !! let me go back and check them out again with that info in mind.
Old Sep 16, 2007 | 11:26 PM
LvTitan's Avatar
LvTitan
From the info I have found so far the T10 = 194 , 168 type bulbs so the Auto Meter one will fit. As for the dual T5's used in the other guages I have found a source for those also. Check out the links.
T10
http://www.genphoal.com/Info194/Info194.htm
T5
http://www.genphoal.com/infoT5/Genph...Info_T5~15.htm
hey oregon, how about giving me a site that's not in china
i'd like to order a few of these, but have no idea how ..
also look at the one , it's a few from the bottom, it has a total of 5 LED's, one in the normal position, and 4 shooting out at the sides, this looks like it would be good for a gauge...
Old Sep 16, 2007 | 11:50 PM
OregonF350's Avatar
OregonF350
Good luck with that, after reading your post I googled up a bunch of LED sites. Everyone of them was for LED's made in China.
Old Sep 17, 2007 | 05:04 PM
LvTitan's Avatar
LvTitan
i dont care if they're MADE in china, but i need to buy them from a company that's here ya know what i mean ?? there's no way i'm giving some chinese website my c/c info !!
Old Sep 17, 2007 | 05:07 PM
LvTitan's Avatar
LvTitan
http://www.jegs.com/webapp/wcs/store..._312382?CT=999
will this one work ??
Old Sep 18, 2007 | 04:03 PM
OregonF350's Avatar
OregonF350
That's the one I originally planned to get. Then I thought if I do the boost guage maybe I could find replacements for the other guages.
Old Sep 19, 2007 | 12:48 AM
LvTitan's Avatar
LvTitan
i got the isspro pyro that came with the color coded face readout.
you know, green numbers , then yellow, then red ,
instead of all the white numbers. it not only looks factory (kind of, factory only has green/red i think) but it really does match well, and there is no white light coming from it, so there is no need to change bulbs on that one.
but you do think if i order that bulb i'll be okay for my boost gauge ?
http://www.isspro.com/proddetail.php?prod=R3607TR
this is my boost gauge above...
Old Sep 19, 2007 | 01:17 AM
OregonF350's Avatar
OregonF350
I ordered one and will let you know for sure when I get it. I'm running the same pyro guages (both post and pre turbo) and I agree that they look good. It's the boost , oil pres , trans temp and coolant temp that are just a shade to white even with the bulb covers. Maybe I'm just to picky.
Old Sep 19, 2007 | 01:25 AM
LvTitan's Avatar
LvTitan
no i know what you mean... if that works, let me know i'll get it on that order with you.
Old Sep 19, 2007 | 05:38 AM
06F250XLTFX4's Avatar
06F250XLTFX4
guys this was a great post, i just installed bulb covers. I agree with you guys the green is to white, i'm really intrested in how those LED's turn out,
Old Sep 19, 2007 | 09:36 AM
LvTitan's Avatar
LvTitan
i also read on one of these sites, that you should take a sharpie or magic marker to the base of the bulb that is not covered by the "bulb cover"..
have you done this to see if it helps ??
have you stacked two of the covers ??
i'm curious as to what is the best way, but so far i'm leaning toward this LED
Old Oct 6, 2007 | 01:28 PM
  #28
06F250XLTFX4
<TABLE class=tborder cellSpacing=1 cellPadding=4 width="100%" align=center border=0><TBODY><TR title="Post 5141228" vAlign=top><TD class=alt1 align=middle width=125>OregonF350</TD><TD class=alt2>I ordered one and will let you know for sure when I get it. I'm running the same pyro guages (both post and pre turbo) and I agree that they look good. It's the boost , oil pres , trans temp and coolant temp that are just a shade to white even with the bulb covers. Maybe I'm just to picky.</TD></TR></TBODY></TABLE>any results with the LED in the gauges, just really curious
Old Oct 6, 2007 | 08:05 PM
  #29
BPofMD's Avatar
BPofMD
Veteran: Navy
Did you guys know that Stewart-Warner made a little computer box called Chameleon with multi-colored LED bulbs? I put the S-W gauges AND the Camelion in my truck a few years ago. You can have the little computer (about a 2X4" box 1/4 thick) change the lamp colors over and over or stop it from rotating the colors and use one of the buttons to manually rotate the color till it's where you want to leave it. Prety much all the colors of the rainbow. I usually leave mine on that greenish dash light color all the time. I do show it off at times tho and just set it to rotate thru all it's colors. Takes about a minute for it to rotate thru all the colors. The little computer control panel mounts right on the dash front just under and to the right a bit of the headlight switch.
Old Oct 8, 2007 | 09:57 AM
  #30
daddgonemadd's Avatar
daddgonemadd
This is too late, but the Dipricol gauges match my '04 factory ones perfect, day and night.
Truck Guy99
Apr 7, 2014 01:23 PM
PhillyB
Feb 1, 2013 01:33 AM
jmaskew
Oct 29, 2008 11:54 AM
'94Nichols
1997 - 2003 F150
Jul 28, 2008 09:46 PM
SHANE_2
2004 - 2008 F150
Oct 25, 2004 01:26 PM
