bulb covers
Old Sep 6, 2007 | 01:05 AM
LvTitan's Avatar
LvTitan
bulb covers
installed gauges tonight, got the isspro boost gauge, but now i need some sort of green bulb cover so that it matches the rest of the gauges.
i love everything about the way it looks, except that at night, i cant stand having the white gauge in a sea of green gauges.. ya know ??
where do i get a green bulb, or a green bulb cover ??
Old Sep 6, 2007 | 09:05 AM
LvTitan's Avatar
LvTitan
anyone? bueller ?
Old Sep 6, 2007 | 12:12 PM
ramsey_71's Avatar
ramsey_71
I've been trying to pick out some gauges for my pickup too and was told the Isspros look like the factory gauges. I seen on one website, (can't remember which one and I don't have time right now to go back and look) that Isspro offers a green bulb cover. Sorry I can't remember the site. I know, I'm not much help, but there is hope for your problem. If I have time in a couple hours I'll help out more.
Old Sep 6, 2007 | 12:26 PM
BGMSPD's Avatar
BGMSPD
the only covers i know are the ones for autometer gauges..probably the same bulb so you could just buy the covers and slip them on over the bulb you have now.
Old Sep 6, 2007 | 04:03 PM
OregonF350's Avatar
OregonF350
Diesel Manor has what you need for under a buck.
http://www.dieselmanor.com/isspro/isspro_accy.asp
I'm still not happy with the Isspro boost gauge color even with the cover. It is still whiter than my others and I'm thinking of trying the LED from Autometer.
http://http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM%2D3285&N=700+ 400442+300156+4294812047+4294812045+115&autoview=s ku
Old Sep 6, 2007 | 05:28 PM
LvTitan's Avatar
LvTitan
well isspro does not show it on their personal website. let me know if you find it please. as far as the look, yes, they look factory in every way. the numbers, the pointers, except they light up white instead of green.
my pyro is the red/yellow/green kind, so it is not an issue, it looks very factory also.
Old Sep 6, 2007 | 05:30 PM
LvTitan's Avatar
LvTitan
http://http://store.summitracing.com...5&autoview=sku
have you considered stacking two of those green covers together ?
Old Sep 6, 2007 | 05:35 PM
LvTitan's Avatar
LvTitan
oregon, i just looked at those led bulbs, do you think they will fit our isspro gauges ? if so, i'm down to order one with you
Old Sep 6, 2007 | 11:36 PM
OregonF350's Avatar
OregonF350
I think it should fit the single t10 bulb on the boost guage. I'm still looking for some that would fit in place of the t5's on the other guages.
I never thought about using two covers on them, might be a cheaper option.
Old Sep 7, 2007 | 01:41 AM
blackhat620's Avatar
blackhat620
Here are the bulb covers on the Isspro website
www.isspro.com/products.php?cat=11
Old Sep 7, 2007 | 10:16 AM
LvTitan's Avatar
LvTitan
aha !! thanks black hat, i was not looking under performance parts, just the accessories. appreciate you finding that for me.
Old Sep 7, 2007 | 04:44 PM
OregonF350's Avatar
OregonF350
From the info I have found so far the T10 = 194 , 168 type bulbs so the Auto Meter one will fit. As for the dual T5's used in the other guages I have found a source for those also. Check out the links.
T10
http://www.genphoal.com/Info194/Info194.htm
T5
http://www.genphoal.com/infoT5/Genphoal%20LED%20Bulbs--Info_T5~15.htm
Old Sep 9, 2007 | 08:09 PM
vlietracer64's Avatar
vlietracer64
This is quoted out of the installation guide on the diesel manor site
"Apply your colored bulb covers to all of your gauge bulbs. The pyrometer and trans temp gauges use (2) T-5 size bulbs each. The boost gauge uses (1) size T-10 (shown here). If you find that your boost gauge is slightly brighter you can mark the bulb with a permanent colored marker as shown above. Just a few lines will do. Make sure you cover the area that the bulb cover doesn't cover. This is where white light can be emitted."
http://dieselmanor.com/diy/PSD3-gauge/PSD60gauge-p1.htm
Old Sep 16, 2007 | 09:45 PM
vlietracer64
Has anyone found t-5 green led to replace the other two guages yet. want to get the bulbs in before i mount my new guages and then have to remove them to reinstall new bulbs, thanks Peter
Old Sep 16, 2007 | 09:53 PM
LvTitan's Avatar
LvTitan
T10
T5
http://www.genphoal.com/infoT5/Genph...Info_T5~15.htm
as far as the T10, i didnt see one on this link that is the one i would need, the bulb i have is some sort of twist lock that goes into the back of the gauge, but the wires dont go to the bulb,
which bulb would i need to order to fit my gauge, ???
