Sponsored by: Real Truck
95-97 e4od swap
Old Sep 5, 2007 | 07:52 PM
Motley Crew's Avatar
Motley Crew
95-97 e4od swap
I have a 95 f-250 4x4 with a 7.3L powerstroke. My transmission overheated and bit the dust. I just got a transmission out of 97 e-250 with a 7.3L powerstroke. Are there any major differences besides changing the 2 wheel drive tailshaft to accept my transfer case? I am adding an aftermarket cooler and a temp guage.
Old Sep 5, 2007 | 09:50 PM
aldridgec's Avatar
aldridgec
You probably can't change the tailshaft housing and have it work. the output shaft is made for a driveshaft, not a transfer case and at the very least will be splined wrong, and probably the wrong length. The entire transmission needs to be disassembled to change it over.
Old Sep 6, 2007 | 07:00 PM
Motley Crew
Thank you, have you ever broken the e4od down to parade rest? How far into the tranny do you have to go to change the output shaft?
Old Sep 7, 2007 | 06:30 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Everything needs to come out of the trans to change the output shaft. It's the last part out, and the first part in during the rebuild.
Old Sep 7, 2007 | 08:02 PM
Motley Crew
I am not afraid of taking it apart and puting it back together. Am I going to be able to take them both apart side by side, keeping everything clean, swap the parts over or am going to have to buy a rebuild kit?
Old Sep 8, 2007 | 12:38 AM
aldridgec's Avatar
aldridgec
Like I said, the trans must be completely disassembled to change the shaft. IMO not worth doing. You WILL need some special tools to reassemble the transmission. Being not afraid, and succesfully doing it are two different things. Automatics are fairly complex and can easily be assembled incorrectly. You will at the very least need new center support bolts. There is no better way to learn though, so if you are up to it, go for it. I would rebuild the trans that came out of the truck, and use the Van Trans for parts in case something happens.
Old Sep 9, 2007 | 07:49 PM
Motley Crew
thank you aldridgec. I am going to rebuild the one in the truck. Although I have never done an automatic transmission I have rebuilt just about everything else. I grew up on a large farm and now I am an electronics technician in the Navy. I am going to get the rebuild kit and the manual. Thanks again for all of the advice.
Old Sep 9, 2007 | 10:52 PM
aldridgec's Avatar
aldridgec
There are a ton of updates, options and upgrades for the e40d. You can spend a fair amount of time finding lots of good info just with a google search. Check it out, and ask questions. I don't rebuild transmissions in general, but do have some knowledge of them, mostly the e40d.
BIGS003
WTB - Parts & other
Feb 7, 2015 07:58 AM
downpeta
New Member Introductions
Nov 30, 2014 09:36 PM
btred1466
Jun 18, 2014 08:58 PM
powerstroker250
Jun 16, 2014 01:52 PM
