axle u-joint size Q's
Old Sep 5, 2007 | 06:43 PM
havi's Avatar
havi
I'll have the Roast Duck
1978 f150 dana 44. Pulled the driver side axle assembly. Seperated the axle shafts to replace the spicer u-joint. The parts store gave me Fed.-mog.- Precision u-joints #371. The cap diameter is correct, but the overall width is too wide by a good 1/8" or more, so the C-clips won't fit. I called them, they said that was the correct one. Does anyone have the Spicer 760x or 297x dimensions handy? Anyone use the 371's successfully?
Old Sep 5, 2007 | 07:13 PM
stryder's Avatar
stryder
The PUJ371 is the correct cross reference number for both the Spicer 760X and 297X. I checked several sites, and they all listed the 371. Have you taken it back apart to see if any of the needle bearings may have came loose? I've had that happen several times no matter how careful I am.
Old Sep 5, 2007 | 07:55 PM
79superduty's Avatar
79superduty
yea needle bearing fell. use lots of grease wont hurt.
CountryBumkin
16
Jun 5, 2017 02:30 PM
SUPERDUTY_08
6.4L Power Stroke Diesel
Jun 28, 2016 05:48 PM
SUPERDUTY_08
Jun 28, 2016 05:24 PM
74Mav
May 19, 2016 01:20 PM
somethingclever
Jun 19, 2014 04:33 PM
