Which U-joints for rear?
Old Jun 2, 2017 | 10:19 AM
CountryBumkin's Avatar
CountryBumkin
I looking at U-joint choices for the rear driveshaft over at RockAuto and getting myself confused.
1984 FORD F-250 5.8L 351cid V8 Universal Joint | RockAuto
It looks like the "Spicer: brand choices have two different bearing cap diameters (1.062" & 1.125"). It looks like they are saying there are different caps sizes on the same U-joint. Is this correct? Seems odd if it is. See part #51204X or 51203X in the Spicer line. And what' the difference between the 03 and the 04?
This is for the rear driveshaft (single shaft), 82 F250 4x4 under 8500GVWR, BW1345, 133" wheelbase.
Does anyone know what the OEM part number is - that would ensure I'm looking at the correct choices in the various brands.
Also, what "series strength" are these u-joint (i.e. 1310, 1330, 1350, etc.)?
Thanks.
Old Jun 2, 2017 | 10:23 AM
CountryBumkin
Maybe I should just disassemble and measure the caps for myself rather than bothering the members here.
But if anyone knows - without going through too much trouble to share .... please post back.
Old Jun 2, 2017 | 11:11 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Not odd...
Ford was known for using conversion (or b*stard) U-joints on many vehicles.
Can't go wrong with Spicer drivetrain components.
Old Jun 2, 2017 | 04:00 PM
Gary Lewis's Avatar
Gary Lewis
Start on the driveshaft page: F250 4wd Driveshafts - ???Gary's Garagemahal
Then go to the U-joint page: U-Joints - ???Gary's Garagemahal
Old Jun 2, 2017 | 04:39 PM
CountryBumkin
Nice Gary!. I have to remember to start with your web site, then come here if I need more info.
Old Jun 2, 2017 | 04:55 PM
Gary Lewis's Avatar
Gary Lewis
Originally Posted by CountryBumkin
Nice Gary!. I have to remember to start with your web site, then come here if I kneed more info.
ROFL! Yeah, right. But, there is some info out there. And if you don't find it then let me know and I'll see what I can do.
Old Jun 3, 2017 | 04:32 AM
FuzzFace2's Avatar
FuzzFace2
FYI besides the cap OD you may need to know if the cap is retained from inside or outside.
Inside has a "C" clip that fits in a groove to the open end of the cap and sits on the inside of the yoke. Sometimes hard to see if there is a lot of grease & dirt.
Outside has a clip that fits in grooves on the yoke on the top end of the cap. Most of the time can be seen as it sits on the outside of the joint assy.
Dave ----
Old Jun 4, 2017 | 01:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by ArdWrknTrk
Not odd...Ford was known for using conversion (or b*stard) U-joints on many vehicles.
The most common is this: C5TZ-4635-F .. 'Combination' U-Joint - Spicer #210392-X / 2 cups are 1310's; 2 cups are 1330's.
It's listed for misc. 1965/79 F100/350's, but it's not listed for 1980 and later.
My former 1965 F100 8' Styleside had a 2 piece driveshaft, took 3 of these puppies.
And be aware that in Ford truck parts catalogs, if the truck has a 2 piece driveshaft: The front driveshaft is known as the coupling shaft.
Old Jun 4, 2017 | 02:17 PM
CountryBumkin
Thanks again for sharing.
My drive shaft is one piece (with slip coupler), its the longer one - 55-57" from yoke to yoke. According to Gary's website info, there is only one u-joint type for my setup (a type/code 42) which is a Spicer 1330 series. Same u-joint type used on both ends.
I'll measure the bearing cap diameter to be sure what I have.
It looks like there are only two choice in the 1330 series - a 1.125" cap (1-1/8) or a 1.0625" cap (1-1/16). The cap-to-cap distance is the same for both at 3.625" (3-5/8). The type 42 is a 1-1/8" diameter cap.
So I believe mine are the C3AZ-4635-M
Old Jun 4, 2017 | 02:39 PM
NumberDummy
My driveshaft is one piece (with slip coupler), its the longer one - 55-57" from yoke to yoke.
I'll measure the bearing cap diameter to be sure what I have. 42 C3AZ-4635-M = 1 1/8" / 41 C3AZ-4635-L = 1 1/6"
So I believe mine are the C3AZ-4635-M (replaced C3AZ-4635-H) '1330' Cleveland steel (aka mechanics) U-joint
Parts catalog clearly states Cleveland steel.
The difference between Cleveland & Spicer u-joints are the location of the clips: On the inside or the outside of the cups.
The cups are also different depending on Cleveland or Spicer.
Old Jun 4, 2017 | 05:05 PM
CountryBumkin
Didn't realize that. I thought the 1310 or 1330 or 1350 referred the strength of the u-joint and applied to all styles (even though it is a Spicer number/code).
My U-joints have the clips on the outside of the caps on the driveshaft and use "u-bolts" where they attach to the yokes.
Old Jun 4, 2017 | 05:09 PM
NumberDummy
I thought the 1310 or 1330 or 1350 referred the strength of the u-joint and applied to all styles (even though it is a Spicer number/code ).
Huh?
But, that's just it, it's not a Spicer u-joint...parts catalog description of C3AZ-4635-M says Cleveland steel, aka mechanics type.
C3AZ u-joints were used in myriad 1960's/70's cars. I got the specs for it from the 1965/72 car catalog, because finding the specs in the 1980/89 truck catalog is a PITA!
Old Jun 4, 2017 | 06:22 PM
KULTULZ's Avatar
KULTULZ
Post
-Universal Joint Identification-
-U-Joint Measuring Guide-
Old Jun 5, 2017 | 08:11 AM
CountryBumkin
It just occurred to me that some of my confusion may be because I had my driveshaft lengthened many years ago - and they may have changed U-joint types. I assumed they reused the ends of the original driveshaft and just lengthened the tube, but I don't actually know what was done (just that it fits the transfer case and pinion yokes fine).
I have the clips on the "outside" of the bearing caps. Which is a "Spicer" type 1330 according the links posted above and from what I have looked up.
Old Jun 5, 2017 | 01:54 PM
NumberDummy
(sigh) Why is it that some members fail to mention info like this "up front" .. then add it later on in their thread, which makes it difficult for other members to figure out what part(s) are correct.
The most blatant example of this that I recall was a guy w/a '75 F250 460, the left exhaust manifold was cracked.
When he got a used manifold from a 1976 F150 460 in a junkyard, it didn't match the original, as the exhaust collector was in a different location.
5 or so responses later, I asked if the 460 was original to his truck, or was it swapped in from something else?
Swapped in from a 1972 Lincoln, so...of course...the manifold was different.
If he had mentioned this swapped in 460 "up front" I would have told him to get the manifold from a 1971/78 460 car.
