3 speed cruisomatic
Old Sep 4, 2007 | 10:35 PM
ras4434's Avatar
ras4434
3 speed cruisomatic
I recently purchased a 65 f100 with a GT390. It has the original 3 speed cruisomatic. I am planning to pull a 4000 lb trailer several times during the summer and want to make sure the transmission is up to the task. I typically hang out in the 61-66 forum but thought I would get input form the "transmission guru's". What are the opinions about the capabilities of the cruisomatic?
Old Sep 5, 2007 | 12:04 AM
stuart1's Avatar
stuart1
No problem. Get an externall cooler first.
Old Sep 5, 2007 | 10:32 PM
ol yeller's Avatar
ol yeller
My C6 is shot but I just got a cruiseomatic I'm putting in. It has the external cooler but doesn't it need to run thru the radiator too?
Old Sep 5, 2007 | 10:45 PM
ras4434's Avatar
ras4434
The cruisomatic that is in the truck has an external trans cooler. It is a seperate unit and does not go through the radiator. The unot sits in front of the radiator. I am thinking about moving it to a different location since I think it is blocking air flow through the radiator and causing the engine to read a bit warmer than I want.
Old Sep 5, 2007 | 11:30 PM
85e150's Avatar
85e150
You would normally plumb your trans cooler so the auxilary unit is first in line, then the one in the bottom of the radiator. That way, your fluid doesn't get too cold to work properly.
Now if your radiator does not have an auto trans cooler, then you may want to hunt one down.
Why? Because it sounds like your radiator is marginal at this point. If the trans cooler is blocking it a bit (air goes through that cooler, so it's not blocking it much) and THAT is causing overheating, you will never hold your temp with a big load on a long hill. Note most cars now have another full radiator (for the AC) in front of the engine radiator, plus oil and trans coolers. And most have no trouble overheating.
Perhaps your radiator just needs a cleaning, but check it out.
Good luck.
ALL AMERICAN BOY
17
Jan 18, 2013 06:11 PM
inkedup
Nov 4, 2007 07:16 AM
tall_texan63
Jun 28, 2004 05:27 AM
HardFordCore
Oct 4, 2003 06:43 PM
mantta
Aug 20, 2002 04:57 PM
