Still No Start
Old Sep 5, 2007 | 05:34 PM
Blankie's Avatar
Blankie
Still No Start
I posted a couple weeks ago with this problem. A little background Truck quit while on a trip to Kentucky. Had it towed to ford dealer, they did not have time to repair. However they did put it on computer. Said IDM was bad and also should check/replace under valve cover harness.
Replaced IDM, UVCH all 4 still no start. No smoke Tach is moving. Help!
Old Sep 5, 2007 | 05:59 PM
Action4478's Avatar
Action4478
You need to find out if you have any HP pressure ...How handy are you ?....
Old Sep 5, 2007 | 06:47 PM
Blankie's Avatar
Blankie
Fairly Handy. Got 50PSI at Schrader. Unpluged sensor in head behind AC compressor. Still no start.
Old Sep 5, 2007 | 06:52 PM
Action4478's Avatar
Action4478
This is what you need ....
Here is what is needed to put a gauge together thanks to Swamps site.
If you don't have access to a scantool, then go to your local hydraulic supply
house, and have them make you up a mechanical gauge. You might spend $60
or so on high pressure hose, fittings, and a quality 0-3500psi liquid filled
gauge....but having this hose available for future diagnostics might be more
valuable than you think.
The hose which you will need will need to be about 40" long, rated for
(minimum) 3000psi working pressure (12k psi burst rating!) with the gauge on
one end, and a #6 female JIC swivel fitting crimped onto the other.
You will also need an individual fitting to screw into the head to go from the
head to the hose.
This single fitting will be a 90degree fitting # 5 "male boss" (sometimes called #
5 o-ring) on one end of the 90, and a # 6 male JIC on the other end of the 90.
Our local hydraulic shop would label such a fitting as 5MB-6MJ90
"JIC" is nothing special...it's just 'hydraulic talk' for a 37degree flare
fitting...standard hydraulic stuff here...nothing rare by any stretch.
Looking at the top of (either) cylinder head, you'll see the factory stainless
braided oil lines (one to each head) then you'll see a few bronze colored
plugs... (Engine off, of course) Using a 5/8" wrench, remove any one of the
bronze plugs, and install the 90deg fitting into the hole. (save the plug for
reinstallation , after testing). and the O-rings are reusable, unless brittle,
cracked, etc...
The single 90deg fitting will have a "jamb nut" on the O-ring side...screw the
fitting into the head, "aiming" the 90 away from the turbo, intercooler pipes,
etc...and then tighten the jamb nut, to "squish" the O-ring also locking the 90
from "spinning" around as you attach the swivel end of the hose to the 90. No
sealants, loctite, or teflon tape are needed on "JIC" or O-ring fittings...and
don't overtighten them...usually about 180degrees with a wrench past finger tight...
Old Sep 5, 2007 | 08:55 PM
bkcowboss's Avatar
bkcowboss
blankie are you still in ky if so I may be able to swing in and help
Old Sep 6, 2007 | 07:52 AM
Blankie's Avatar
Blankie
No, I hauled Truck back home to Western NC. But thanks for the offer.
Old Sep 6, 2007 | 08:16 AM
Diesel Dave 04's Avatar
Diesel Dave 04
do you have a Wait to start light?
Old Sep 6, 2007 | 08:34 AM
Blankie's Avatar
Blankie
Yes I have a wait to start light. checked hpop level it is full. One thing I did notice while trying to start is that the check engine light comes on while cranking but goes off as soon as I stop cranking.
Old Sep 6, 2007 | 08:48 AM
Diesel Dave 04
Can you hear the injectors start tickin while you are cranking it they should start to tick once your oil pressure gauge goes up.
If not the the IPR is stuck open and need to be replaced.
Old Sep 6, 2007 | 09:20 AM
renchr56's Avatar
renchr56
Another cheap fix would be to replace the CMP sensor. Ford has updated to Part # F7TZ-12K073-B. But I have a truck in my shop now that when I hooked my scanner up, I checked the Hi pressure to the injectors and found that it only had 50psi and was really sluggish to build up. After the pressure got to 450 or better it started. Realistically you should have the data checked that way first just to be sure you are getting the correct pressures
Old Sep 6, 2007 | 02:04 PM
Blankie's Avatar
Blankie
Just checked the high pressure, it was 1500 while cranking. What is the CMP sensor and where is it located.
Old Sep 6, 2007 | 02:36 PM
renchr56's Avatar
renchr56
WOW 1500. Never had mine do that be4.
Oh the Crankshaft sensor is located just above and to the right if the harmonic balancer. It is held on by a 10mm bolt. You will be able to see the pointer on it.
Old Sep 6, 2007 | 02:40 PM
Action4478's Avatar
Action4478
With a guage or a scanner?...
Old Sep 6, 2007 | 02:41 PM
Blankie's Avatar
Blankie
I replaced it about a month ago. (Dosen't mean it's not bad). Will the Tach move if it is bad.
Old Sep 6, 2007 | 02:45 PM
Action4478's Avatar
Action4478
The jury is still out on that one ..There doesn't seem to be any rhyme or reason to CPS failure....
