rich mixture at idle
frequency is normally required to check the sensor’s
output. But you can also use an ordinary tachometer
because a tach can display a frequency signal.
Here’s the procedure:
1 Set the tachometer to the four-cylinder scale
(regardless of how many cylinders the engine has).
2 Connect one tachometer lead to the middle terminal
on the MAP sensor and the other tachometer test
lead to ground.
Connect the two jumper wires as in the diagram above,
attaching each end terminal on the sensor to its
respective wire in the wiring connector.
4 If you want to measure engine vacuum so you can
correlate it to a specific frequency reading, connect
a vacuum gauge to a source of manifold vacuum
on the engine, or tee the gauge into the MAP
sensor hose.
5 Turn the ignition ON and note the initial reading.
The reading on the tachometer should be about
454 to 464 at sea level, which corresponds to a
frequency output of 152 to 155 Hz.
6 Start the engine and check the reading again.
If the MAP sensor is functioning properly, the
reading should drop to about 290 to 330 on the
tachometer, which corresponds to a frequency
output of about 93 to 98 Hz. No change would
indicate a defective sensor or leaky or plugged
vacuum hose.
now it may also be a vacum hose and the best way to find that out would be metering resistance between the wires and see if they check out with the manual.
