Crank Endplay?
Old Sep 4, 2007 | 03:29 PM
RJR99SS's Avatar
RJR99SS
Crank Endplay?
I just picked up my block from the machinist, i'm getting ready to throw everything together, but the machinist said something about having to "set" the endplay on ford cranks. I asked him what he meant, and he started talking about tightening it down and prying around with a screw driver and checking it with a dial indicator. I didnt really understand what he was talking about, it sounded just like you're checking it, i dont see how that would "set" anything. anyone know what he was talking about about?
Old Sep 4, 2007 | 07:47 PM
JBradley500's Avatar
JBradley500
Thats how you check it, but you use thrust bearings to change the distance.
You get thicker ones to decrease the distance and you sand off material of it with 320 grit sand paper to thin it to desired thickness (.005"-.010")
Old Sep 4, 2007 | 09:10 PM
mark a.'s Avatar
mark a.
Turn a counter weight close to the thrust bearing till you can get 2 flat screw drivers in, one on each side of the bearing bulk head. Gently tap 2 screw drivers in on each side forcing the crank in one direction or another, it doesn't really matter which way. The idea is to align the 2 bearing halves up using the cranks thrust surface before you tighten them down. After that hold a piece of soft metal, brass or lead on the snout of the crank and strike it with a heavy hammer, firm but not hard. Do the same to the rear of the crank. Set up a indicator & check the clearance.
MtTheJeffro
13
Sep 1, 2015 09:36 AM
1950FordF1
Nov 26, 2014 06:06 PM
frdnut
1997 - 2003 F150
Mar 30, 2014 07:37 PM
mitchell390
16
Nov 17, 2011 08:19 AM
montster69
Sep 13, 2004 08:29 PM
