widow makers
Old Sep 4, 2007 | 06:41 PM
bobj49f2's Avatar
bobj49f2
Originally Posted by truckdog62563
An F-6 rat rod!? That'd be quite a site.
Maybe he's going for something like this:
http://www.truckblog.com/trucktube/n...sized_rat_rod/
Now that's scary!!
Old Sep 4, 2007 | 08:56 PM
reamer's Avatar
reamer
You can have my solid rims, they are 22.5" five-bolt SOLID rims with brand new 9R 22.5 radials. All six rims and tires, but you have to buy my completly-rebuilt '48 F-5
All new everything. for 10G.
Old Sep 4, 2007 | 09:11 PM
48-56's Avatar
48-56
You got details on the f5? I got an F648
Old Sep 4, 2007 | 10:20 PM
reamer's Avatar
reamer
Frame up re-build, (Frame and liners both POR-15ed then reassembled) The following list are new parts; all 4 corner leaf springs, all brake lines (including the rubber ones) all wheel cylinders, master cylinder, Brake booster, 5-core super cool radiator, both water pumps, NOS style wire harness, high beam switch, interior cab light, tie rod ends, drag link, pitman arm, all cab glass, cab mounts, all rubber glass seals, stainless grill, fuel pump, gas lines. Electric wipers with two wiper arms.
Rebuilt list: carb, steering box, horn, hydrolic(sp) dump cylinder, PTO driven pump, instrument cluster, window regulators, diaphragm for the two speed rear,
7000 miles on 239 8BA flattie, no burn, no leak, T-98 SYNCORNIZED tranny (no double clutching here) Eaton 2 sp with 5:83 ratio, 5-lug Solid 22.5" rims with six 9R 22.5 radials.
Mimimal body rot was cut out, new patch panels welded in, Painted Original Glade Green, and Tuscon tan grill.
also have a NOS brush guard!
See my gallery.
Old Sep 5, 2007 | 06:46 AM
bobj49f2's Avatar
bobj49f2
Reamer,
You mentioned inside dome light, I would like to see a picture of it. My F-2 had a dome light in it when I tore it apart, 20+ year ago. I lost it but found another just like it. I'm just wondering if yours is like the one I have. I have never seen one in another '48-50. I've seen them in '51-52s.
Old Sep 5, 2007 | 11:15 PM
48-56's Avatar
48-56
That F5 sure is sweet! I love those bigger trucks. Nice Job.
Old Sep 6, 2007 | 04:17 PM
reamer's Avatar
reamer
Bob,
I'll get ya a photo of the interior light
Reamer
Old Jul 16, 2008 | 10:49 AM
bryanswens's Avatar
bryanswens
Welding Widow Makers
OK so I actually really like the nostalgic look of these widow maker wheel and I am kind of cheap and don't wand to spend a lot of money and time looking for replacement wheels but is it possible to just weld the two piece wheel together. I would think with equipment now days it should be easy to install a tire on them or am i missing something. I would think any shop that does semi tires probably has some really good machines for changing them.
Old Jul 16, 2008 | 11:49 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
No such luck. You could weld the halves together, but you'd destroy a new tire trying to get it over the rim's lip. The old wheels used what was called a 5° lip design that held the bead firmly in place. Hence the name of the "widow maker" is a Firestone RH-5°. Modern wheels use tubeless tires that have a 15° lip and a drop center that lets modern tubeless tires fit into the drop center when mounting. Here's a comparative pic of the 5° and 15° designs. Stu
Rooster403
1997 - 2003 F150
Jul 21, 2016 05:18 PM
wvabeer
2009 - 2014 F150
22
Jun 22, 2015 07:12 AM
old uhaul
18
Jul 20, 2014 09:16 PM
limited4life
Jan 26, 2011 11:08 AM
zxkeller
Dec 22, 2010 08:35 PM
