is 302 an interference engine?
Old Sep 4, 2007 | 12:53 AM
godblessmud's Avatar
godblessmud
probably been asked before,
but does the 302 run an interference system. meaning, do the valves come far enough down into the combustion chamber that they overlap where the piston raises to before detonation (meaning they could be bent/shattered by the piston in the event of a timing chain failure)?
Old Sep 4, 2007 | 04:58 AM
HemiEater's Avatar
HemiEater
i think they will hit except anything with the E6 heads on it.
Not sure......I have had them slip a tooth or two without any problems......
Old Sep 4, 2007 | 03:47 PM
godblessmud
wait, is that answer a yes or no?
Old Sep 4, 2007 | 04:45 PM
dragogt's Avatar
dragogt
what year is your engine, stock or modified, on my 86 gt i cant really mess with the heads to much w/o notching the pistons for valve reliefs b/c of the flattops I think your safe with one of the newer engines 88-95
Old Sep 4, 2007 | 08:11 PM
godblessmud
its a 1990 302 EFI stock
Old Sep 5, 2007 | 05:13 AM
HemiEater's Avatar
HemiEater
why do you ask??? I have never had that happen but that doesn't mean it wont.
Old Sep 6, 2007 | 07:35 PM
godblessmud
i was just curious
Old Sep 7, 2007 | 12:37 AM
LxMan1's Avatar
LxMan1
Stock, it may live, if you have larger valves or more cam lift, it will hit for sure.
Old Sep 7, 2007 | 12:38 AM
godblessmud
im not to keen on that use of the term "may live" haha
Emmett Coffman
Jun 20, 2015 08:13 PM
BigShelby
Feb 4, 2014 07:38 PM
bbsitum
1997 - 2003 F150
Jun 12, 2012 01:42 AM
maverick1701
22
Sep 19, 2009 11:50 AM
gavin
Jan 2, 2004 09:12 PM
