How to fix Body rust
I'm a original owner of a 93 Aerostar. It is 2wd, with 69000 mile. It runs great. But it has some rust in the pasenger side's lower edge. The metal for real jack point is rusted very bad. The state inspector said that is a sturcture problem. I don't how and where I can get this fix. Please help!!!
Thanks,
David
Thanks,
David
body shop or welding shop that specializes in frame repair
the Aero has a semi frame U channel members welded to Unibody floor pan
shop should be able to weld repair plates to good steel on both ends of rusted out section
welding on auto bodies has high fire danger, professionals only
panels are avail. after market for lower body sheet metal
dbarracuda
11-13-2002 04:27 PM
