Sponsored by: Auxito
Tranny's done.....
Old Sep 2, 2007 | 03:26 PM
scottie2hottie's Avatar
scottie2hottie
Tranny's done.....
My tranny finally kicked the bucket. She's had a rough life no doubt, been grinding into gears for about 25,000 miles now. Four people have learned to drive stick and learned to do burnouts in her(my self and my two siblings and my fiancee) Last night on the way to poker night I made a turn on to a road, and when I shifted from 2nd to 3rd, the gear shifter went up to third, but the tranny didn't. It's still in second and the shifter won't budge....Now where do I go from here. truck has 160,000miles. kinda beat up, but not too bad. It's an '01 reg cab flare side. I'm thinkin about toying with it a bit. I guess we'll see.
Old Sep 2, 2007 | 05:10 PM
loony2000's Avatar
loony2000
Best thing to do would be to make a visual inspection of the transmission. When the tranny died in my 97 f-150, there was a lot of visual damage. Take the tranny fluid pan out and look for significant amounts of metal in it - that's a good indicator.
Other than that, the best way to go would be to remove the tranny from the vehicle and proceed with either rebuilding or replacing it.
Old Sep 2, 2007 | 05:15 PM
MisterCMK's Avatar
MisterCMK
I'd get a new used transmission from a junkyard and toss 'er in.
After that, rebuild yours!
Old Sep 2, 2007 | 06:09 PM
StephenH's Avatar
StephenH
Sounds like you got your money's worth out of it. Rebuild it stronger!
Old Sep 2, 2007 | 09:18 PM
LxMan1's Avatar
LxMan1
Well Loony, it's a 5-speed so no pan to remove. You can pull the shifter out of the top and see if the internal linkage is in a bind, but it sounds like the syncro's are shot and possible shift rod damage. If there is nobody in your area that rebuilds manual transmissions, then you may find a decent one at a local salvage yard.
Old Sep 2, 2007 | 11:10 PM
loony2000's Avatar
loony2000
There's no pan for the tranny fluid? I thought all tranny's -- stick or auto -- needed tranny fluid.
Or am I missing something?
Old Sep 2, 2007 | 11:14 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The manual trannies have a fill plug and a drain plug...no pan.
Old Sep 2, 2007 | 11:17 PM
loony2000's Avatar
loony2000
Well, then to modify my advice, drain the fluid into an appropriate size pan and check for significant metal content.
Sorry about that.
Old Sep 2, 2007 | 11:48 PM
scottie2hottie
Yeah just got er home today and had a busy day today, jes havent had the time to mess with it. Guess she got a little scared I just sent in my final payment last monday. Should have let her know she wasn't goin anywhere LOL
Old Sep 3, 2007 | 12:38 AM
LxMan1's Avatar
LxMan1
They do that sometimes. Ya gotta talk real nice to them and let them know that the romance isn't over
PaulTheBum
Jan 9, 2014 12:06 PM
cookie88
24
Dec 26, 2012 07:16 AM
wwgk1980
Jun 27, 2012 09:38 PM
86sixbanger
1983 - 2012 Ranger & B-Series
Sep 17, 2011 07:50 AM
rammstitch
Aug 18, 2008 07:19 AM
