Intake Q. 390 same as 352?
Old Sep 2, 2007 | 11:41 AM
Snowking's Avatar
Snowking
I am in the process of acquiring performance parts for m 1967 352 project truck. but as we all know there are a great abunance of 360/390/428 stuff. I know the 352 has a smaller bore but would a intake that was on a older 390 fit my 352?
Thanks all
Old Sep 2, 2007 | 12:25 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Yes it would. The main thing you want to watch is the port match between the intake and the heads. Older intakes are lowrisers with larger ports. What heads do you have now? If you have a lowriser head the match will be fine. If you have later heads like C8's or D2's the match will not be as good but still work fine.
Old Sep 2, 2007 | 02:42 PM
Snowking's Avatar
Snowking
Where would I find those numbers, i took off a Valve Cover and found 7F6.
Old Sep 2, 2007 | 07:58 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Head casting number in between the center 2 sparkplugs. You found the date code. 67/June/6th. Good chance they are C7AE-6090-A heads with a June 67 date code.
brbuchanan
Jun 11, 2015 12:27 PM
ford390gashog
Aug 28, 2004 04:42 PM
400Nut
Jun 20, 2004 10:16 PM
hjm3inpa
Aug 2, 2003 08:35 AM
bigblockhead
Mar 19, 2000 09:45 PM
