1994 f150 help please
Old Sep 1, 2007 | 07:20 PM
kmjasey1's Avatar
kmjasey1
just got the truck and when you put it in drive it is in third and will have to pull it to 2nd to tack off
problem started about 5 to 6 months after engine swap but just a thought
checked all that i can think to check i am a gm tech for 14 years but dont know alot about fords
on the test drive i noticed it is only getting to 2nd and 3rd and no overdrive and 1st
have plans to rebuild but if i can fix it with out it
just a ride for 4 or 5 months untill i get back on my feet
so please if you can help
Old Sep 1, 2007 | 08:46 PM
brown 4x4's Avatar
brown 4x4
Have you checked for codes yet? They should probably tell you something. If there's no codes it probably points more toward a rebuild. Do you know if it's a 4R70W (302 engine only) or an E4OD?
Kinda funny, but I worked on a GM pickup once with only third gear and it ended up being a wire rubbed through blowing the trans fuse. But I don't think Ford has a separate fuse; I think they get their power through the PCM relay.
Old Sep 1, 2007 | 09:03 PM
kmjasey1's Avatar
kmjasey1
it has 5.8 and have no way other than going to auto zone and getting them to read it for me so i will try that and let you know as soon as i can
Old Sep 1, 2007 | 09:30 PM
quicklook2's Avatar
quicklook2
it is easy to read codes.
go to fordfuelinjection.com for how.
Old Sep 2, 2007 | 07:38 AM
lostin90s's Avatar
lostin90s
yep read your own . on above sight its step by step and they also have how to test the sensors ETC
Old Sep 2, 2007 | 08:21 AM
booneyrat75's Avatar
booneyrat75
It sounds like the same problem I had in my '94. Mine was the later '94 with an AODE tranny. When I found out the repair bill ANYWHERE in town was going to be $1500 to rebuild, I opted to swap everything out. I wouldn't advise taking the route I took but at the same time, I still have a hard time with thinking $1500 was a reasonable price to rebuild an automatic tranny. Are you POSITIVE you have a 351? It took a lot of searching to figure out what the deal was on mine but basically, I had a intake that said 5.0 but I had a 5.7's firing order. The last I heard was that I had the 1995 5.0 HO engine because of the November '94 build date my truck had. Good luck!
Old Sep 2, 2007 | 08:31 AM
lostin90s's Avatar
lostin90s
$1500 is the norm for auto overdrives around here. Not installed !
And yes the late 93 up 5.0 have the 5.8 firing order .
Old Sep 2, 2007 | 01:08 PM
kmjasey1's Avatar
kmjasey1
my intake has 5.8 on it
it is an xl long bed with two tanks and x cab
have not pulled codes yet but will be to day
Old Sep 5, 2007 | 09:15 PM
kmjasey1's Avatar
kmjasey1
talked to a ford tech and put a scan tool on the truck and it was full of codes
and got to looking and found the connector on the pass side of trans was unpluged
and was melted on the exhaust pipe so to the junk yard we go
let yall know how it turned out
Old Sep 5, 2007 | 10:53 PM
Mr. M's Avatar
Mr. M
$10 bucks says the replacement connector nails the problem. Hope the Ford Tech didn't charge you for the code scan... nothing a paper clip couldn't tell ya!!
Good Luck
Mike
Old Sep 11, 2007 | 06:32 PM
kmjasey1's Avatar
kmjasey1
he did not charge me and helped me and also told me what to get next for my abs problem so and the connector cost me $50 not one in the 5 junk yards i looked at
but the trans is shifting good and the only thing i hate about the truck is the fuel mileage 12 mpg i sold my other truck that was getting 38 mpg big jump
will take sum time to adjust to that
thanks for the help
Old Sep 11, 2007 | 07:15 PM
alz's Avatar
alz
What truck gets 38mpg? I need one of d'em.
Old Sep 23, 2007 | 10:16 AM
kmjasey1's Avatar
kmjasey1
95 toyota truck 38mpg with the air on but needed bigger truck
the toy did not like the 8x25 car hauler when it was loaded
i put 9 clutchs in it in 3 years but i made due with what i had
and the truck did pull it but taking off up hill was murder on the clutch
Old Sep 23, 2007 | 10:27 AM
quicklook2's Avatar
quicklook2
no toyota truck gets 38 mpg.
Old Sep 24, 2007 | 06:32 PM
kmjasey1's Avatar
kmjasey1
that is what the calculator said as per the gal of fuel per the milage =37.??????
and was about 38 to 37 miles per gal and that was at about 45 to 50 mph the whole tank- i only work about 3 miles from home no hills strait there i can not explain it just does that is the only time it gets driven
blieve it or not
RAY1986F150
22
Nov 3, 2011 08:57 PM
jst1fix
Jul 8, 2011 04:36 PM
ralf12
Jul 22, 2010 12:33 PM
88blkranger
1983 - 2012 Ranger & B-Series
Sep 10, 2004 12:20 PM
