1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
train horn wiring
Old 09-01-2007, 01:37 PM
6.0superduty's Avatar
6.0superduty
6.0superduty is offline
Question train horn wiring
I put a set of train horns on my truck a couple weeks ago. I was wondering where my stock horns are located. Which wire do I hook my trigger wire for my solenoid to? My horn solenoid uses an all-time ground and a momentary positivs system. I want it hooked up so that when I use the panic button or lock my truck, the train horns will sound. I have a 2004 crew cab superduty with a PSD if that helps with the wiring diagram. Thanks for your help.
Kyle
Old 09-01-2007, 01:42 PM
riggz's Avatar
riggz
riggz is offline
Are you trying to completely remove the stock horns? Most people wire up a switch to a relay so they can select between regular horn and air horn. You can't have it setup so that the air horns will work with the alarm system only (at least not easily).
I hope you don't live in a populated area. Blasting the train horns everytime you lock the truck is a bit of a nusiance to the public.
Old 09-01-2007, 01:50 PM
6.0superduty
No, I am not trying to remove the stock horns. I have a switch already to select between air horns and stock horns, but it is wired from the horn switch on the steering wheel. I was wondering if I could find the wire that runs out to the stock horns before it leaves the cab and make my connections there. I think that when you press the horn button, you send a request to a computer and then to the horns. Is there somewhere online I can find a wiring diagram?
Old 09-01-2007, 02:06 PM
BGMSPD's Avatar
BGMSPD
BGMSPD is offline
6.0
i think i have a wiring diagram for that truck...let me check and i'll send it to you.
Old 09-01-2007, 07:53 PM
darth_calvin's Avatar
darth_calvin
darth_calvin is offline
Try this thread 6.0
https://www.ford-trucks.com/forums/5...highlight=horn
I wired mine directly from the steering wheel horn button where it is - triggered, but Bear Hunter shows where you can hook in behind the fuse panel for a + trigger horn wire.
Enjoy the horns!!
Matt
Old 09-02-2007, 10:04 AM
riggz's Avatar
riggz
riggz is offline
I'm 99.99999% sure the horn does not run through the computer. The alarm system will most likely use a relay that will honk the horns.
Old 09-06-2007, 12:15 AM
Hitekmobile's Avatar
Hitekmobile
Hitekmobile is offline
Tie it in behind the fuse panel, press the horn and listen for the relay. Do not go to column, the horn trigger coming off your column is a ground trigger in the yellow airbag sleeve cable. If you do use this trigger, do not test with test light use a digital multimeter.
Old 09-06-2007, 06:45 PM
6.0superduty
It was a yellow wire with green tracer behind the fuse box closest to the steering column. Works awsome. thanks.
Kyle
NUKEHEAD1001
Aftermarket Products
04-07-2015 05:50 PM
Duckmang
07-28-2013 11:40 PM
87wreckerman
17
02-17-2009 06:18 PM
2 stroke man
12-10-2007 07:06 PM
scottb1014
2004 - 2008 F150
12-19-2004 10:03 PM
Quick Reply: train horn wiring
