door hinge bushings
Old Sep 1, 2007 | 11:05 AM
billyf150's Avatar
billyf150
door hinge bushings
what is the best way to change the door hinge bushings-do you have to take the door off- I tried to knock the pin out with a punch and a hammer-nope
Old Sep 1, 2007 | 11:14 AM
quicklook2's Avatar
quicklook2
you need to cut it in half with a dremel tool.
not too bad a job.
i think it is covered in articles section at the top of the page.
Old Sep 1, 2007 | 11:15 AM
92F150Flare's Avatar
92F150Flare
Welcome to FTE
put a jack under the door and take the pressure off.......have someone hold the top so it doesn't tip......then cut the hinge in the center and use a punch to drive the halves out.
The new one will slide in from the top and you can use the jack to get the door in the right spot for it.
Good Luck
Bob
Old Sep 1, 2007 | 11:53 AM
quicklook2's Avatar
quicklook2
you can get them at the auto parts store 'help' section.
Old Sep 1, 2007 | 12:03 PM
billyf150's Avatar
billyf150
thanks for the quick replys
Old Sep 1, 2007 | 03:16 PM
lostin90s's Avatar
lostin90s
yep I did 4-5 of them . And they never last . Mostly because peaopl I buy truck form don't care about a 100000 + mile truck . But if not much play will last a longtime .
I pull under garage door rail and use a rastchet strap to support door (take while to get balanced.) And marke and remove door bolts it will them swing out of way > (I have big hands its easyier for me.
jvmcc
Aug 31, 2014 11:44 AM
alchemist1
Feb 1, 2014 09:39 AM
MNTBUGGY
Feb 20, 2012 07:50 PM
Darryl 123
1997 - 2003 F150
Apr 7, 2011 11:01 AM
Yacomash800
Oct 26, 2010 07:34 PM
