clutch problems
Old Sep 1, 2007 | 02:57 PM
rustee90-150's Avatar
rustee90-150
clutch problems
i recently put a new clutch in my 90 150 302 with a five speed once the engine gets hot when i let the clutch out to go it starts to bouce and shake its fine when its cold whats wrong is something warped?
Old Sep 1, 2007 | 02:58 PM
MisterCMK's Avatar
MisterCMK
Did you put a new pressure plate on? Did you resurface the flywheel?
Also, is it a wet clutch?
Bdox's Avatar
Bdox
Warped or contaminated with something. Any leaks up top?
Old Sep 1, 2007 | 02:59 PM
MisterCMK's Avatar
MisterCMK
If it is indeed a wet clutch, I could see not bleeding it properly causing problems when the fluid heats up
Old Sep 1, 2007 | 03:00 PM
rustee90-150
they didnt do the flywheel or a new plate.
Old Sep 1, 2007 | 03:01 PM
MisterCMK's Avatar
MisterCMK
The flywheel should be resurfaced whenever you do a clutch and there should always be a new pressure plate
Old Sep 1, 2007 | 03:02 PM
rustee90-150
its a hydrolic clutch and there is a small leak at the top close to the back of the tranny
Old Sep 1, 2007 | 03:10 PM
MisterCMK's Avatar
MisterCMK
I would try and fix that leak first and see where that puts you. It is probably the slave cylinder. It shouldn't make a huge difference, but I have found that if you get the obvious stuff taken care of first, the small problems go away.
Old Sep 1, 2007 | 03:18 PM
rustee90-150
i found the bill they put in a new slave cylender and a carquest clutch
Old Sep 1, 2007 | 03:24 PM
Bdox's Avatar
Bdox
"They" I guess you mean a shop did this?
Take it back to them.
Old Sep 1, 2007 | 03:40 PM
MisterCMK's Avatar
MisterCMK
I'd take it back to them and tell 'em to fix it
