Valve Cover Removal
Old Sep 1, 2007 | 10:11 AM
ss150's Avatar
ss150
Valve Cover Removal
I have a leak from my drivers side valve cover on my 302, so I am going to replace the gasket. My question is, do you have to remove all the wiring and stuff on top of it, or is it possible to lift it up and change out the gasket without moving the wiring? Also, if anyone off the top of their head knows the bolt size that would help as well. Thanks.
Old Sep 1, 2007 | 02:47 PM
lostin90s's Avatar
lostin90s
10 mm I think been awhile
The wire harness come apart at the fender well and you can fold up out way . The plug wires can be left on and taken from clips for movement. The upper manifold will have to come off for other side .(it will leak day after you fix the other) Buy a cheap torx set (need 40 i think )for a cordless drill use 1/4 extension and socket tape the torx bit in . (this set up will fit between groove in upper intake to get at torx bolt. )
Get the good none cork gaskets they last longer. Any problems PM me.
Old Sep 1, 2007 | 02:57 PM
MisterCMK's Avatar
MisterCMK
Rubber gaskets are a MUST. Cork WILL leak
Old Sep 1, 2007 | 06:02 PM
302 F-150's Avatar
302 F-150
Definately use fel-pro gaskets. I made the mistake of using cheap gaskets on my valve covers and intake and had to change them about a week later. I used fel-pro's and they haven't leaked since.
Old Sep 1, 2007 | 09:30 PM
ss150's Avatar
ss150
Ok, thanks guys. I got fel-pro gaskets. I thought they were rubber, but turns out they were cork. I'm going to trade them in sometime and get the rubber. I went out there to take the valve cover off and found out that the bolts weren't even hand tight. I decided for now to just tighten the all down a little better and see if that fixes it. I will drive it a couple more days, and if it continues, I'll change them out. I figure I may have only been over torquing them, but I figured it was worth a shot since I planned on changing them anyways. I'll let you guys know what happens and if I have any ,ore questions. Thanks again.
Old Sep 1, 2007 | 11:14 PM
mebe2k's Avatar
mebe2k
almost every Ford motor i've worked on has had super loose valve cover bolts? maybe the hot/cold cycle loosens them? I know tightening them usually doesn't work.. best to replace the gaskets.. you can also clean the insides of the valve covers and paint 'em up nice a pretty.
Old Sep 2, 2007 | 03:16 AM
Decipha's Avatar
Decipha
on my 302 they were loose as well IIRC they were 7/32 bolts and you need a deep socket for a couple of them, i believe the torque rating is 18 ft lbs on the valve cover bolts
Old Sep 2, 2007 | 07:34 PM
Peter94's Avatar
Peter94
When the valve cover is off be sure to inspect it. Our ranger had a leaky valve cover. I replaced the gasket, and it still leaked. I let it go for a while and later when I replaced the intake gasket I took a look at the leaky valve cover and it was actually rusted through/cracked at the very end causing the leak.
fleetsidebob
21
Jan 24, 2012 09:49 PM
mr.fordneck
Feb 22, 2011 08:31 PM
jr1960
Aug 30, 2008 03:32 PM
Jrock909
16
Oct 13, 2006 12:01 AM
-=PEAKABOO=-
Apr 27, 2006 03:46 PM
