Valve Cover gaskets install
Old Aug 22, 2006 | 08:55 AM
Jrock909's Avatar
Jrock909
Gang what is all involved in replacing valve cover gaskets on a 92 302EFI motor... I have oil residue on my plug wire boots and know for a fact that my valve covers are leaking. Probably due to age or even crappy gaskets who knows. All I do know that is my valve covers are leaking....
Old Aug 22, 2006 | 09:41 AM
Conanski's Avatar
Conanski
You may have to remove the upper intake to get the pass side off, but once that is done it's easy. Get the Ford 1 piece metal core/rubber coated gaskets if you are going in.. they'll never need replacing again.
Old Aug 22, 2006 | 10:23 AM
biggreentank's Avatar
biggreentank
You will probably want to get a new gasket that fits between the upper & lower intake as well.
Old Aug 22, 2006 | 01:36 PM
Jrock909's Avatar
Jrock909
Conanski, how many bolts are we talking to take the upper intake manifold off? Another thing is what else can I look for when taking the valve covers off before I just slap some new gaskets on and move on? Is there any thing I can look at such as valve adjustment, etc...
Thanks Gang -- Jason S.
Old Aug 22, 2006 | 02:23 PM
Conanski's Avatar
Conanski
6 bolts hold the upper intake to the lower, 1 is a torx down in the middle you'll need a 1/4 drive to get at it. There is likely a support bracket on the passenger side, and you'll need to remove the throttle cables and vacuum lines as well.
No adjustments necessary inside the motor.. that's the beauty of hydraulic lifters. You'll want a new intake gasket as indicated and maybe a PCV valve while you are at it.
As soon as you remove the upper plenum, run some wide masking tape over the runners in the lower to prevent dropping something like a bolt into the intake.
Don't forget to remove the tape before putting the upper back on.
Old Aug 22, 2006 | 06:36 PM
Jrock909's Avatar
Jrock909
Can you buy good valve cover gaskets at the part store...?
Jason
Old Aug 22, 2006 | 08:14 PM
shooter05's Avatar
shooter05
I always just nixed the gasket and used Blue Goo. It seems to hold just as well.
Old Aug 22, 2006 | 08:42 PM
Conanski's Avatar
Conanski
No. All you'll get are cork gaskets. They cannot take any preload without crushing and will always leak. The metal core Ford gaskets don't crush, will not leak, and are very well priced in comparison!!! I was surprised to find they were cheaper than a few popular namebrand gaskets.
Old Aug 22, 2006 | 09:31 PM
Blurry94's Avatar
Blurry94
...Another thing is what else can I look for when taking the valve covers off before I just slap some new gaskets on and move on? Is there any thing I can look at such as valve adjustment, etc...
It'll make life MUCH easier to pull the upper intake, and any if part of the gasket rips/tears, then replace it. While you have the upper intake off, pull the throttle body off (have a new gasket for that), and its components, and give it a good cleaning.
Old Aug 22, 2006 | 09:37 PM
Jrock909's Avatar
Jrock909
Blurry thanks for the suggestion of cleaning my throttle body while it's off the intake, but I already cleaned the throttle body thoroughly with throttle body cleaner and a brush. Do I really need to go to the dealership just to get gaskets that kinda sucks. How long of a job is this drawn out to be? How much am I looking for in cost for the gaskets?
Old Aug 22, 2006 | 09:42 PM
Jrock909's Avatar
Jrock909
Gang I was going to ask another question. What are some good nice aftermarket valve covers that have all the provisions for our EFI Truck motors?
Old Aug 22, 2006 | 11:00 PM
EPNCSU2006's Avatar
EPNCSU2006
Ford motorsports has some nice aftermarket valve covers that will fit the trucks. I have the stamped steel chrome ones on my truck.
Old Aug 23, 2006 | 12:29 AM
Jrock909's Avatar
Jrock909
So all ford motorsports valve covers should work on our EFI trucks...?
Old Aug 23, 2006 | 12:48 AM
Blurry94's Avatar
Blurry94
No, not all of them. Pay close attention to the oil filler tube location, and if they require aftermarket breathers. Ebay sometimes has aftermarket valve covers, however, check to see where the oil filler/breather locations are and just go from there.
As far as the valve cover gasket go, the only place I've seen the steel/rubber coated valve cover gaskets is from a Ford dealership. It doesn't hurt to go to a local parts store and ask to see if they have the same gaskets though...if they don't, then go to Ford.
If you have already pulled/cleaned the throttle body then it wont hurt to at least flip the throttle blade open and see what it looks. If it's dirty, then clean it, and its components.
Old Aug 23, 2006 | 06:54 AM
EPNCSU2006's Avatar
EPNCSU2006
The EFI mustang valve covers will not work because they have the oil filler on the passenger side. FMS makes truck specific aluminum valve covers with the raised filler on the drivers side just like stock, but they are pretty expensive.
