intake upgrade
Old Sep 1, 2007 | 01:38 AM
  #31
c00nhunterjoe's Avatar
c00nhunterjoe
hey i like my spider...lol, but i would say based on your opinion of mine that your would favor the left side as it has a less aggressive bend to it, and my spiderman pipe, is dirt cheap and will work with the intake upgrade, yours will not as yours seems to be the exact size of the intake and wont accept the larger plenum
Old Sep 1, 2007 | 01:39 AM
  #32
Pest007's Avatar
Pest007
yep, but I think its a 2 piece setup come to think of it now, the ram part on the left, and then the piece off the turbo, i think together it was about $120, still cheaper than those intakes from beans!!
Old Sep 1, 2007 | 01:42 AM
  #33
Pest007's Avatar
Pest007
well we agree to disagree... J?K I just went that route so that my pipes would all fit perfect since the banks pipes for the intercooler were made for that setup, and not the spider piece
Old Sep 1, 2007 | 01:44 AM
  #34
wreckit72's Avatar
wreckit72
They were probably easier to get also.
Old Sep 1, 2007 | 01:45 AM
  #35
c00nhunterjoe
oh, i agree, if you bought the banks pipes you might as well buy the whole kit, it makes no sense to go the other route, but for the intake plenum upgrade yours wont work without getting adapter to go from your 2 inch pipe to the 3 inch intake, mine will be a direct bolt on and a stright through shot instead of my current stepped down version
Old Sep 1, 2007 | 01:46 AM
  #36
Pest007's Avatar
Pest007
not to change this thriller subject, but do you guys have pics of the FPR shim, been thinking of doing that if its not too hard before I go to the diesel drags tomorrow night...
Old Sep 1, 2007 | 01:48 AM
  #37
c00nhunterjoe
the 3\4 inch nut on the regulator, unscrew it and pull the spring out, drop the bb in there and put the spring in and the cap, takes longer to open the hood and climb in then it does to do the mod
Old Sep 1, 2007 | 01:50 AM
  #38
Pest007's Avatar
Pest007
is the FPR screen in there too? should prob clean that as well
Old Sep 1, 2007 | 01:52 AM
  #39
wreckit72's Avatar
wreckit72
Look here for the pics. https://www.ford-trucks.com/forums/5...light=fpr+shim
  #40
c00nhunterjoe
no its not, that is more involved and you may want to wait till afterwards to do that one, it is in the housing though, in this pic the screen is where the fpr is bolted to the fuel filter housing
Old Sep 1, 2007 | 01:55 AM
  #41
wreckit72's Avatar
wreckit72
Here it is.
Old Sep 2, 2007 | 01:02 PM
  #42
tjbeggs's Avatar
tjbeggs
Joe I think the early 99's still didn't have the larger intake plenums and the early 99 intake spyder doesn't have 3 inch outlets either does it. its no problem but you won't be able to use the late superduties boots to connect the two. you will still need a reducer boot but it will actually be a expander boot to fit the smaller intake spyder and the larger plenum. I think the early 99 outlets are like 2.5 or so.
you can find those types of boots are turbohose.com or something like that.
Old Sep 2, 2007 | 01:50 PM
  #43
c00nhunterjoe
hmmm, i will go check, i know its bigger but i never measured it, be back in a few
Old Sep 2, 2007 | 02:29 PM
  #44
c00nhunterjoe
tj, you are correct, i am a 2.5 inch outlet stepped down to the 2 inch intake
and here is a photo of how close the x-pipe is to the fuel filter housing
Old Sep 2, 2007 | 05:16 PM
  #45
tjbeggs's Avatar
tjbeggs
yikes that is pretty darn close!
