Engine Washing
Old Aug 31, 2007 | 11:41 PM
kawa's Avatar
kawa
Engine Washing
I did a search and the only thing found was on 5-2007 tndiesel washed his engine using "Simple Green" and several others chimed in but noone stated warnings re do's and don'ts re washing and possibly pending pit falls.
I just want it to run afterwards.
Roger
Old Aug 31, 2007 | 11:45 PM
c00nhunterjoe's Avatar
c00nhunterjoe
dont hose the air cleaner, dont hose the idm, dont hose the pcm connector, keeping the idm and pcm totaly dry is impossible but dont spray them directly, simple green works good, for tough grease and grime i use wheel cleaner, just dont let it dry on the motor,
Old Sep 1, 2007 | 12:04 AM
wreckit72's Avatar
wreckit72
Only use a hose and not a pressure washer. If you have the kwik filter or Tymer intake you can put a bag over it to keep it dry.
Old Sep 1, 2007 | 12:13 AM
c00nhunterjoe
walmart bags work wonders.....,i really like the wheel acid, after if dries i spray with tire foam, this sounds liek tomarrows project, maybee
Old Sep 1, 2007 | 12:19 AM
kawa's Avatar
kawa
Thanks Joe, but........I don't think I know just where the IDM & PCM are located. I'll be pulling that cover over the fuel pump and concintrating my efforts in that area as well as the drriver's side of the engin to asscertain if I have a leak on that side or not.
Roger
Old Sep 1, 2007 | 12:26 AM
wreckit72's Avatar
wreckit72
The fuel pump is mechanical so not really a need to cover it.
Old Sep 1, 2007 | 12:36 AM
c00nhunterjoe
idm is the rectangular box bolted to the drivers side inner fender, the pcm connector is on the firewall as the inner fender meets the wall under the brake booster, what you want to spry the crap out of wont get hurt
Old Sep 1, 2007 | 12:49 AM
kawa's Avatar
kawa
Great! I know where those dudes live I just didn't know their names. I also have the assistance of unlimited compressed air to blow the water away from the elect. connections.
I agree with the other guys re a clean engine is a happy engine. Who/what doesn't feel good after a bath???
Roger
Old Sep 1, 2007 | 06:42 AM
MLCinNCTX's Avatar
MLCinNCTX
Roger
I had a 115# German Shepard that liked to argue that point.
Old Sep 1, 2007 | 09:02 AM
kawa's Avatar
kawa
I'll bet his negative feeling were "Before and/or during" not after.
Old Sep 1, 2007 | 12:29 PM
westtntrucker's Avatar
westtntrucker
should try and baptise a 20 pound tom cat. A german shepard is baby *****! LOL!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 1, 2007 | 12:33 PM
MLCinNCTX's Avatar
MLCinNCTX
If I had a 20# tom cat I would sell it to the Korean cafe in town and that sucker would be on the menu this evening. Cat on a Stick special.
Old Sep 3, 2007 | 08:12 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Also dont spry the alternator, and wash your engine, when it is warm not hot and if you can, use always warm water (it really helps, ask TJ).
Cesar Salcedo
Jul 31, 2016 09:55 PM
johnsonjf
Mar 23, 2015 05:22 PM
frdf250
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jun 7, 2011 04:27 PM
dalkins1
Jun 30, 2007 09:28 PM
buddythomashou
Oct 22, 2005 09:03 PM
