power washing engine?
Old Jun 30, 2007 | 10:02 AM
dalkins1's Avatar
dalkins1
I was wanting to power wash my dirty engine in hopes to locate a fuel leak. If I do this when it is cold does anybody see a problem or have a concern? I was going to spray some engine clean on the fuel housing area and valley then power wash it on a low nozzle pressure setting?
Old Jun 30, 2007 | 10:43 AM
tjbeggs's Avatar
tjbeggs
Don't power wash it! There are way too many elctronics on our engines. The best thing to do is to use lots of engine cleaner. I use simple green. I do it with the engine just warm not hot. And then rinse with hot water if you can from a low pressure hose. Cold water works just not as well. Everytime I have pressure washed my engine (2 time) it caused problems.
Old Jun 30, 2007 | 08:42 PM
echo95's Avatar
echo95
Go with what Tjbeggs posted. I've seen several posts with troubles after doing a power wash. Too many electronics to get screwed up.
Old Jun 30, 2007 | 09:28 PM
dalkins1's Avatar
dalkins1
Thanks for info,,,,, did the simple green stuff,,,,, got engine pretty clean,,,now just gotta locate the diesel leak,,,,,,, I am going to park it for 2 days and see if filter cannister drops level,,, might be leaking there from what another post suggested.
Syncrowave
19
Oct 31, 2016 09:08 PM
landers0440
Jun 1, 2014 09:08 PM
PPrash
May 6, 2011 03:06 AM
Yougotthehit
Jan 18, 2011 01:19 AM
Butch(OH)
Jul 10, 2006 09:41 AM
