No Start
Old Aug 31, 2007 | 08:18 PM
FARM69's Avatar
FARM69
No Start
My PSD has been sitting for about two weeks now. I went out to start it this evening and it won't fire up. It turns over nice and fast but there no combustion. The tach moves, and I'm not getting any smoke that I can see when I'm sitting in the cab turning it over.
My external injector o-rings are needed replaced and I'm planning on taking them out tomorrow morning. Could that have any affect to the "no start"
Any ideas? Always started in the past....
Old Aug 31, 2007 | 08:48 PM
Cuda_jim's Avatar
Cuda_jim
Maybe the o rings is the cause of it not starting, but it was running, rught? Maybe the injector bled down and you need to crank on it a long time to get her going.
Check all the normal suspects, HPOP level, #22 fuse under the hood, UVC connectors fuel pressure. The CPS could still be bad even though the tach is moving, if you got one try it.
Old Sep 1, 2007 | 12:05 AM
FARM69's Avatar
FARM69
I just replaced the CPS not even a month ago. I'll check #22 in the morning. However, I'm thinking the injectors bleed down.
What is the UVC connector?
Thanks Cuda
Old Sep 1, 2007 | 12:12 AM
c00nhunterjoe's Avatar
c00nhunterjoe
under valve cover harness, you have 4 of them, 2 in each valve cover
Old Sep 1, 2007 | 12:31 AM
FARM69's Avatar
FARM69
It doesn't seem likely that the UVC would go bad because of the truck sitting for a week or two.
Old Sep 1, 2007 | 12:34 AM
c00nhunterjoe
nope, did you check the hpop resevoir?
Old Sep 1, 2007 | 12:35 AM
wreckit72's Avatar
wreckit72
My truck has been hard to start after sitting also. I can't drive right now so it just sits there. It will start but it takes quite a bit of cranking. Yesterday before my dad was going to start it and move it I checked the HPOP and it was full after sitting for three weeks. It did start eventually and run good. Would the UVC harness be the problem with it running good after starting?
Old Sep 1, 2007 | 12:38 AM
c00nhunterjoe
fuel pump probably loses its prime or the valleys in the head drained back, wouldnt worry about it
Old Sep 1, 2007 | 12:42 AM
wreckit72's Avatar
wreckit72
Come to think of it, last winter when I changed the fuel pump and cleaned the engine off it looked like the fuel line disconnects at the bottom front of the motor may have been leaking.
Old Sep 1, 2007 | 07:12 AM
FARM69's Avatar
FARM69
Hpop level appears to be close 1/2 to 3/4 full. How far should I fill the hpop up?
Fuse #22 looks good.
I have to put the battery charger on it, but how much cranking would it take to re prime the system?
Old Sep 1, 2007 | 08:48 AM
c00nhunterjoe
level is good, fuse is good, sounds like fuel might be dropping off, or could still be oil, at this point a scanner such as fordforever's is needed so you can read your pid data, while cranking, that way you can see if the icp is slow to build
Old Sep 1, 2007 | 09:51 AM
FARM69's Avatar
FARM69
Fuel pressure should build fairly fast while cranking right? Oil pressure should come up unless one of my o-rings completly took a drive and it's not allowing any pressure to build up
Old Sep 1, 2007 | 10:12 AM
Cuda_jim's Avatar
Cuda_jim
Yep & yep on the oil/fuel pressures.
Try checking the ICP, but I though you should be getting a code, maybe not? Joe, do you know?
Leave the connector on the ICP & Back probe it.
Here is a pict of the connector and test.
https://www.ford-trucks.com/forums/5...need-help.html
Old Sep 1, 2007 | 10:35 AM
1997F-350's Avatar
1997F-350
need 9.6 volts for it to fire. are you getting smoke while cranking? if not it may be time to pull the vc's off or try someones idm.
Old Sep 1, 2007 | 11:22 AM
FARM69's Avatar
FARM69
No smoke when its cranking. However, I haven't cranked on it that as the batteries didn't last too long. I got the charger on it now.
I haven't checked the codes as I don't have a code reader.
I was actually planning on taking my injectors out today to put my stage II's in but I don't want to start that unless I know it will run before I start that project.
Also, pulled the UVC off and the pigtails have oil on them. I thought that was kind of strange?
