No Start
Old Sep 1, 2007 | 11:23 AM
Action4478's Avatar
Action4478
Originally Posted by FARM69
No smoke when its cranking. However, I haven't cranked on it that as the batteries didn't last too long. I got the charger on it now.
I haven't checked the codes as I don't have a code reader.
I was actually planning on taking my injectors out today to put my stage II's in but I don't want to start that unless I know it will run before I start that project.
If it didn't take much to run the batteries down, that may be the only problem....
Old Sep 1, 2007 | 12:57 PM
c00nhunterjoe's Avatar
c00nhunterjoe
get good batts on and try again, it usually wont smoke untill its cranked for a bit. as for fuel pressure while cranking, it should build within a couple of revelutions, but the max while cranking is normally 20 psi, as for oil pressure, the gauge should come up after 10 or 15 revelutions maybee more, but thats low pressure oil, not high, if the low pump is shot, your resevoir would be dry,
Old Sep 1, 2007 | 02:07 PM
FARM69's Avatar
FARM69
You mean the hpop res would be dry? I'm gonna go out and give it a try now. Batts should be juiced up.
Old Sep 1, 2007 | 03:08 PM
1997F-350's Avatar
1997F-350
your gonna need your batteries fully charged for your injector swap too. it will take a while to crank it over for that also.
Old Sep 1, 2007 | 04:30 PM
c00nhunterjoe
yes, if the lubrication oil pump is no good then your high presure pump resevoir would be dry
Old Sep 1, 2007 | 04:37 PM
FARM69's Avatar
FARM69
Ok guys... The truck started on the first turn! I must have a slow draw off of something.
Progress on removing the injectors is going well. I already have the valve covers off and waiting to start on removal of the injectors themselves.
Thanks for the help guys.
tigerfan79
Jan 21, 2014 01:46 PM
thesellout77
Mar 2, 2013 04:23 PM
wanta79
1983 - 2012 Ranger & B-Series
Jan 29, 2012 08:27 AM
77f250400
Jan 20, 2011 06:10 PM
markjerry
Jun 29, 2006 06:19 AM
