Pushrod not oiling
Old Aug 31, 2007 | 05:23 PM
desperado_18_2000's Avatar
desperado_18_2000
Pushrod not oiling
The 300 in my F-150 has a pushrod that doesn't oil. With the valvecover off the engine and it idling there is plenty of oil up top, but one rocker/pushrod that won't oil itself. I'm thinking this may be a bad lifter. But i figured i'd ask here first, as this might explain the rattling noise i've had in this engine since i rebuilt it.
I certainly hope i didn't wipe the cam...or cause any other nefarious damage to the engine.
Old Aug 31, 2007 | 05:38 PM
Redtires019's Avatar
Redtires019
I would remove the pushrod and look or blow thru it. It may just be stopped up. If not then look further. As for the cam being wiped watch that valve while turning the motor over (by hand or at cranking speed only)and visually compare its lift to the others. If it is badly wiped it will be obvious.
Old Aug 31, 2007 | 06:04 PM
desperado_18_2000
I've had that pushrod out before when i had noticed the same thing. I've ran a wire coat hanger through it, and used an air compressor to blow through it. And it always does this. It always has "some" oil in it, but not nearly enough, and you can tell it isn't oiling properly by watching the rockers with the valve cover off.
When i get back into town next week i'll give it a look over, as i've got a lot to do to it when i get back. Thankfully shes been parked the past two months.
Old Sep 1, 2007 | 06:43 AM
srercrcr's Avatar
srercrcr
Pushrod 101: So the oil pump delivers oil to the cam, each lifter gets plenty of oil, and sends it up the pushrod? If so, either the lifter is starved or plugged?
Old Sep 1, 2007 | 11:03 AM
desperado_18_2000
To be honest i wouldn't know if any of the lifters were plugged. This is a brand new set i installed when i rebuilt the engine onto the stock cam. I'm trying to recall what brand they were...i do know i remember buying em at O'reillys. I'm just not sure what there house brand would be. I may end up having to pull all of the lifters out and inspect em. Along w/ my pushrods.
I'm just hoping its nothing too serious...
Old Sep 1, 2007 | 04:57 PM
80broncoman's Avatar
80broncoman
Either way just because the lifters are new does not mean that each one was made properly. If you have to replace that lifter. If not the rocker, pushrod and valve tip will suffer.
mrlightrail
Aug 25, 2007 09:41 PM
fuzz
Jun 29, 2004 01:03 AM
1952
Nov 17, 2003 09:17 PM
HangGlider
Jun 23, 2003 11:56 PM
1972 Ford Thunderbird 429 V8
13
Apr 13, 2003 09:07 PM
