Pushrods and Lifter Installation Info needed, ASAP.
Old Aug 25, 2007 | 03:50 PM
mrlightrail's Avatar
mrlightrail
Was in the middle of changing the oil pump on my 351M, and discovered a mangled pushrod in the oil pan. I'm going to pull the tappet covers and see if any are missing, but hoping that it was an old part from the rebuild. What I need to know, is how many pushrods/lifters do I need to replace to deal with this issue if one is bad/missing? The entire bank, the entire engine, or just the cylinder that has problems? Need to keep the costs down, I'm not working, and can't afford a lot of outlay on this truck right now. Going to order parts soon, so the sooner I can get an answer, the sooner I can go get parts....
Old Aug 25, 2007 | 04:12 PM
ubereal2's Avatar
ubereal2
Been there 2
Been through that recently. Myself I'd replace ALL 16 pushrods, and lifters. I still have some noises that I can't get rid of, because I only replaced what I seen bad...........
Bob
Old Aug 25, 2007 | 04:48 PM
mrlightrail
Popped off the tappet covers, and discovered one pushrod missing, and another one bent. What would cause this issue? My thoughts are frozen lifters.
Old Aug 25, 2007 | 06:41 PM
twobitranch's Avatar
twobitranch
First you should check the valves and make sure they aren't sticking. As long as they are all free then you need to check to make sure the pushrods are the right length on all valves. You can do this simple by rotating until the valve is closed completely and you should be able to turn the pushrod easily by hand but there should be no extra clearance with the rocker arm. Then rotate until the valve is completely open and take a pipe wrench (or anything else that will work for you) and see if you can move the rocker to open the valve a little more. As long as you can you should be okay. There is a good chance you could get away with only replacing the bad pushrods, but I would at least replace the lifters that go with them at the same time if you don't find anything else that has caused the problem. I just had a similar problem on my 400 and chose to replace all lifters and pushrods for insurance though. Good luck!
Old Aug 25, 2007 | 06:44 PM
mrlightrail
Got the intake manifold off, and discovered about 4 more bent push rods. On all bent rods, the corresponding lifter was stuck. (no spring action at all) I'm ordering all new pushrods and lifters for the truck. Should I replace the rocker arms as well?
Old Aug 25, 2007 | 09:18 PM
ubereal2's Avatar
ubereal2
I didn't find anything wrong with my rockers on my 79 with the 400M, one bent pushrod, and one bad lifter. Wish I'd changed them all. Have a tick (Lifter) that is driving me crazy. As long as you're valves are opening and closing (nothing stuck) you maybe safe with the lifters and pushrods. Would get a good look at those rocker arms though...........
Old Aug 25, 2007 | 09:29 PM
mrlightrail
Does anyone know of a reference FAQ, or page that will give me instructions on how to put new pushrods and tappets in and get it all spec'd correctly so I don't have to do this again soon?
Old Aug 25, 2007 | 09:41 PM
ubereal2's Avatar
ubereal2
You need to get you're old lifters out. I alway's soaked my new lifters in new clean oil to get them full. Put you're new lifters in, place you're new pushrods in the pocket of the lifter. The rocker arm need to be torqued, not sure what measurment can get that tomorrow. Get new gaskets for you're intake manifold, and valve covers........
Kenny1968
Aug 22, 2012 07:21 PM
wrenched
21
Apr 23, 2007 09:47 AM
welavalle
Sep 17, 2006 02:30 AM
bandittfb
13
Aug 19, 2003 06:19 PM
HangGlider
Jun 23, 2003 11:56 PM
